CS:GO STUTTER PLEASE HELP!
Go to solution Solved by Enderman,
I have the latest drivers for nvidia yes
But did the problem start happening after you updated the drivers?
If so, go to http://www.geforce.com/drivers and download the previous drivers that you were using before you updated.
Then do a clean install of the older drivers you downloaded and restart your PC, then it should be fixed.
I used to run cs go perfectly but now whenever i reload weapons, inspect my weapons, or switch weapons the game stutters and the animation glitches out. I also get alot of minor rubber banding even though my ping is 30-40 constantly. I have verified cache and even reinstalled the game on my ssd but nothing changes. Another problem that started occuring today is that it makes me reinstall the DirectX everytime i start the game. PLEASE HELP ME
CPU: i7 8700 GPU: Asus ROG Strix GTX 1080 Mobo: Gigabyte Z370 Gaming 5 Ram: 16GB EVGA SuperSC SSD: Samsung 850 EVO 250GB
HDD: Seagate Barracuda 2TB PSU: TX650M Case: NZXT S340 Elite OS: Windows 10 Mouse: Logitech G403 Mouse Mat: HyperX Fury S Pro XL
Keyboard: CM Masterkeys Pro S (reds) Headphones: Sennheiser HD598 Monitor: Asus 24' MG248QR Devices: IPhone 11 Pro Max + 13' Macbook Pro
https://linustechtips.com/topic/256084-csgo-stutter-please-help/
did you update the drivers before this started happening?
https://linustechtips.com/topic/256084-csgo-stutter-please-help/#findComment-3504404
https://linustechtips.com/topic/256084-csgo-stutter-please-help/#findComment-3504427
https://linustechtips.com/topic/256084-csgo-stutter-please-help/#findComment-3504441
still glitchy
https://linustechtips.com/topic/256084-csgo-stutter-please-help/#findComment-3504551
Fuck my life its happening again
https://linustechtips.com/topic/256084-csgo-stutter-please-help/#findComment-3504619
Check for new windows updates and install all of them.
https://linustechtips.com/topic/256084-csgo-stutter-please-help/#findComment-3504759
Now that worked thanks alot man
https://linustechtips.com/topic/256084-csgo-stutter-please-help/#findComment-3510820
You're welcome :D
https://linustechtips.com/topic/256084-csgo-stutter-please-help/#findComment-3511559
