You guys might have more experience with this pump then I do.
At first it was fine. Running it on the 5th dial and having Koolance CTR-SPD12X2 Dual 12V pump controller set at 7 volts for about two weeks now.
However as you can faintly see in the clip, the flowmeter is barely spinning, and as i ramp up the V on the controller, theres a huge whine sound. Is my pump fine and flow meter is just restricting? or vice versa.
In the loop.
Tubes: primochill 3/8ID 1/2OD hardline tubing
Fittings: Primochill Rigid Ghost Fittings
Ek: EK D5 X-Top Pump Top w/ D5 Vario Pump
CPU block: XSPC Raystorm Intel
Radiator: Alphacool UT60 480mm
BItspower: Visual Flow meter
Res: 250m Dual Helix
Here a clip of it
CPU i7 3770K@4.6Ghz Motherboard  Asus Maximus V Extreme Ram 4x4GB Corsair Dominator Platinum @ 1866Mhz GPU 3-Way Sli EVGA Gtx 780 //Core@1.2Ghz/Mem@7Ghz// PSU Corsair Ax1200i Storage OS 2xSamsung 840 Pro 128GB // 2xOCZ Vertex 4 128GB // 2xWD Red 4TB Keyboard Corsair K70 Mouse Steelseries Xai Cooling Custom Dual Loop Case Corsair 900D
https://linustechtips.com/topic/256051-d5-noise/
7v is pretty low, can you not put it to 12v I know some D5 pumps can run up to 24v can't they?
Chernobyl
AMD FX8350 @ 5GHz | Asus Sabretooth 990FX R2 | 16GB HyperX Savage @1950mhz CL9 | 120GB Kingston SSDNow
EK AMD LTX CSQ | XSPC D5 Dual Bay | Alphacool NexXxoS XT45 240mm & Coolgate Triple HD360
Kraken
Intel i5 4670K Bare Die 4.9GHz | ASUS Maximus VII Ranger Z97 | 16GB HyperX Savage 2400MHz | Samsung EVO 250GB
EK Supremecy EVO & EK-MOSFET M7G  | Dual 360mm Rads | Primochill CTR Phase II w/D5 | MSI GTX970 1670MHz/8000MHz
Graphic Design Student & Overall Nerd
https://linustechtips.com/topic/256051-d5-noise/#findComment-3505117
https://linustechtips.com/topic/256051-d5-noise/#findComment-3505552
I know but have you actually turned yours up to 12v to see if that is the case? It does look slow but then again if it is running at near half its designed voltage i would expect it to be that slow.  ;)
EDIT: also, if this pump is brand new, it could be trapped air in the pump, Dazmode did a customer build where he mentioned this stating customers often return the product believing it is faulty when all it was is air.
Second EDIT:
I just watched the video of Daz and your's back to back and it sounds the same, because you have used hardline tubing I cant suggest moving it around to try and dislodge the air, you could try tapping it ever to slightly to try and help push it out. It sounds like it's just plain air trapped.
Chernobyl
Kraken
https://linustechtips.com/topic/256051-d5-noise/#findComment-3505582
ive been running the loop for 2 weeks, why would air pop up now?
https://linustechtips.com/topic/256051-d5-noise/#findComment-3505704
Could of collected there over time? like tiny bubbles? I'm unsure as to how to get rid of the air but if you check out Dazmode customer build episode 3 i believe or tell me how to embed videos on here I could show you, it sounds exactly the same as what he is describing in the video.
Chernobyl
Kraken
https://linustechtips.com/topic/256051-d5-noise/#findComment-3505925
could the pump be put on incorrectly or too tight by ek?
https://linustechtips.com/topic/256051-d5-noise/#findComment-3506593
I'm sorry I can't help you with your question, but what is the little spinning wheel? I always wondered what those were for. Sometimes I just see them in random places on people's loops.
Current PC build: [CPU: Intel i7 8700k] [GPU: GTX 1070 Asus ROG Strix] [Ram: Corsair LPX 32GB 3000MHz] [Mobo: Asus Prime Z370-A] [SSD: Samsung 970 EVO 500GB primary + Samsung 860 Evo 1TB secondary] [PSU: EVGA SuperNova G2 750w 80plus] [Monitors: Dual Dell Ultrasharp U2718Qs, 4k IPS] [Case: Fractal Design R5]
https://linustechtips.com/topic/256051-d5-noise/#findComment-3506664
It's a visual flow meter @Spev it's to show you that the pump is still functioning and indicates your flow rate through your loop (depending on placement).
Possible but given you said that it wasn't making that noise then over the past 2 weeks the noise has developed I'm still placing my bets on it being air trapped in the pump top like Dazmode says in his video, he even shows you that the noise only starts at position 5 on the pump. Like I said, I'm not sure how to move the air other than gently tapping the assembly while you have the pump running at just below where the noise starts, you should see the bubbles go eventually but it isn't a 5 min job it takes time for the air to shift apparently. Are you certain the noise is from the pump and not the flow meter?
Chernobyl
Kraken
https://linustechtips.com/topic/256051-d5-noise/#findComment-3506908
Turn the loop on, tilt your case and watch for bubbles, might be hard with the colored coolant, keep tilting it until the noise goes away, just trust me before you rip everything out and RMA the pump.
Chernobyl
Kraken
https://linustechtips.com/topic/256051-d5-noise/#findComment-3506943
If I bought one, should I install it towards the end of my loop to ensure that water is being pumped decently enough throughout the entire thing?
https://linustechtips.com/topic/256051-d5-noise/#findComment-3507035
yea im pretty sure its the pump, cause my gpu loop has its own pump and its dead silent.
https://linustechtips.com/topic/256051-d5-noise/#findComment-3507461
The pressure in your loop will pretty much equalize through out so shouldn't really matter where you put it so long as it's not infront of the pump outlet, putting it near the res inlet would do fine or generally where ever you can see it best.
It's air, unless you ran the pump dry it will be air stuck in the pump top you have fitted, tilt your case until the air is pushed out and the noise should go away.
Chernobyl
Kraken
https://linustechtips.com/topic/256051-d5-noise/#findComment-3507591
but that shouldnt explain low pressure even or if it does have that much air wouldnt it have that imprellor grinding sound?
https://linustechtips.com/topic/256051-d5-noise/#findComment-3510948
http://youtu.be/hGsa8oD1bTw?t=4m42s
Watch this please.
Then read this. http://forums.overclockers.co.uk/showthread.php?t=18324488
Chernobyl
Kraken
https://linustechtips.com/topic/256051-d5-noise/#findComment-3511013
How would u fix this problem then? i tried tilting it 90 degrees this morning, didnt fix the problem.
https://linustechtips.com/topic/256051-d5-noise/#findComment-3512681
Like I said, it isn't a 5min job, it's trapped there for a reason, try a few positions for a good while and if the problem still continues then yes the pump is faulty, but in that forum post I linked you too, he said himself it was fine then all of a sudden it made noise much like yours.
Chernobyl
Kraken
https://linustechtips.com/topic/256051-d5-noise/#findComment-3516169
So I contacted EK and they declared pump is defected.
Thanks for your inputs guys.
https://linustechtips.com/topic/256051-d5-noise/#findComment-3525412
