Looks pretty good, you could go cheaper Motherboard and thats really it
https://linustechtips.com/topic/256018-build-advice/#findComment-3503756
Get thermal paste Artic Cooling MX-4 or Noctua NT-H1. :P
All the other stuff seems ok.
System 1: Thermaltake Element Q - Thermaltake 220W SFX - Asus AT5IONT-I mini-ITX - Intel® Atom™ D525 onboard 1.8GHz Dual-Core HT - Integrated NVIDIA® ION™ - 2x 2GB Kingston DDR3 - Samsung 120GB 840 Series - Scythe Kama Rack 3.5 - Asus DVD-RW
System 2: Thermaltake Element Q - Thermaltake 220W SFX - Asus E2KM1I-DELUXE mini-ITX - AMD E2-2000 onboard 1.75GHz Dual-Core - Integrated AMD® Radeon HD 7340 - 2x 4GB Kingston DDR3 - Samsung 120GB 840 Series - Scythe Kama Rack 3.5 - Asus DVD-RW
Building: Bitfenix Prodigy Black - Corsair AX860i - Asus Maximus VII Impact - Corsair Hydro Series H100i - Intel® Core™ i7 4790K - Asus Matrix Platinum GTX 980 4GB - Corsair 16GB Dominator Platinum 2x 8GB DDR3 2400MHz CL10 - Samsung 1TB EVO 840 Series
https://linustechtips.com/topic/256018-build-advice/#findComment-3503766
