Help removing a virus or some-sort
Solved by FizzyFantom,
Deleting the registry entry may solve that issue, but there may be more than that one entry. Have you tried using AdwCleaner?
https://toolslib.net/downloads/viewdownload/1-adwcleaner/
I suggest you try this first, it's very good at finding adware that antivirus programs overlook. If it fails to solve your problem you could try deleting the registry entry.
Featured Topics
VinSen ·
1
Fahizzle ·
6
INotPablo ·
Posted in CPUs, Motherboards, and Memory1 -
nugget1414 ·
Posted in General Discussion0 -
2
KN923 ·
Posted in Troubleshooting1 -
Subrand0m ·
Posted in Networking0
