Hey there friends :-)
I've spent a bunch of hours learning HTML and CSS over at " http://www.codecademy.com/learn
and i'm now looking for a similar place to continue coding but all on my own this time.
So far i've looked over at " http://www.reddit.com/r/learnprogramming/comments/1echwu/what_is_the_best_ide_for_web_development/ " and found
http://codepen.io/ " which is pretty much exactly what i wanted (though it'd like to have the third box for code to be php or Python instead of JavaScript.)
However this is bound to a website so i cant use it if i dont have internet acces. Do you guys know a similar editor that i can download and use on my computer?
Thanks in forehand!
My web-browser freezes whenever i try to create links, therfore i just wrote the url.
Redliquid~
https://linustechtips.com/topic/255757-ide-for-web-developing/
A local IDE for web development? I personally just use dreamweaver, but a few other people like using eclipse with web dev plugins which is a pain in the ass in my opinion, but it is free. If you need something sort of like codepen, have a look at http://codepad.org/ It's not user friendly at all, but you can test PHP/Python and a bunch of other things.
To get started with a local solution though, you need a local webserver because PHP is a server side language of course therefore you need a server. I suggest going and downloading XAMPP. Most others recommend WAMP because it only has the bare necessities you need, so it's more lightweight. But XAMPP is so much prettier, and WAMP makes me want to torture a water bottle or something weird like that, so just grab XAMPP
You mentioned you needed Python as well, follow the link below to find out how to integrate Python with XAMPP
http://www.biogem.org/blog/convert-xampp-into-xamppp/
Finally, since you have a webserver for your testing now anyway, a full IDE might not be the best solution. A simple but popular text editor with support for a large selection of languages such as notepad++ or the ever popular sublime text might be a much better solution, like, way better. I only use dreamweaver because a lot of the other things have sucky built in FTP capabilities for transferring to my live server
EDIT: Oh, and XAMPP also has a Filezilla distro built in for FTP stuff anyway
I am good at computer
Motherboard: Gigabyte G1 sniper 3 | CPU: Intel 3770k @5.1Ghz | RAM: 32Gb G.Skill Ripjaws X @1600Mhz | Graphics card: EVGA 980 Ti SC | HDD: Seagate barracuda 3298534883327.74B + Samsung OEM 5400rpm drive + Seatgate barracude 2TB | PSU: Cougar CMX 1200w | CPU cooler: Custom loop
https://linustechtips.com/topic/255757-ide-for-web-developing/#findComment-3501355
Hm...codepad didnt seem like a good place to create websites using html and css, they didnt even show up as Languages.
I'm not planing on hosting the website, i'd just like a good enviroment to build in that updates as i go along so i can see visually what i'm actually coding.
Redliquid~
https://linustechtips.com/topic/255757-ide-for-web-developing/#findComment-3501482
It's a good thing you follow this topic. Apparently I don't have permission to quote you at the moment.. What's with that @Slick @LinusTech @MrWizard
Anyways, codepad was suggestion for PHP only testing. Seeing that you just want a environment to dev in, the XAMPP with Python solution with a text editor like notepad++ is probably the easiest way to go. All you need to do is install XAMPP and save the .html/.php/.py etc files directly in the htdocs folder created by the XAMPP installation and you can visually see what you're coding directly in the web browser by navigating to either localhost or 127.0.0.1
https://linustechtips.com/topic/255757-ide-for-web-developing/#findComment-3501496
I would suggest using Sublime Text 3 or Adobe Edge Code. I've used both and they're quite good, but I use Sublime Text as my daily driver.
15" MBP TB
AMD 5800X | Gigabyte Aorus Master | EVGA 2060 KO Ultra | Define 7 || Blade Server: Intel 3570k | GD65 | Corsair C70 | 13TB
https://linustechtips.com/topic/255757-ide-for-web-developing/#findComment-3575094
DreamWeaver, NetBeans, Notepad++
Intel Core i3 2100 @ 3.10GHz - Intel Stock Cooler - Zotac Geforce GT 610 2GB Synergy Edition
Intel DH61WW - Corsair® Value Select 4GBx1 DDR3 1600 MHz - Antec BP-300P PSU
WD Green 1TB - Seagate 2.5" HDD 1TB - Seagate Barracuda 500GB - Antec X1 E.
https://linustechtips.com/topic/255757-ide-for-web-developing/#findComment-3617214
