So for the past couple of weeks i've been trying to configure my new gaming pc. For the most part this has gone well, but i have run into a little bit of a predicament. I simply cannot choose which cpu to go with, but i've narrowed it down to 2. a haswell 4770K or a ivy-bridge 3770K. i know that the haswell takes less power but generates more heat, and the ivy-bridge requires more power but overclocks better. the other thing that makes it hard is that on microcenter.com there only like $30 appart. so if anyone could help me i would gladly appreciate it.
P.S.: I do plan on overclocking the cpu.
Here are the builds.
Haswell
CPU: Intel core i7 4770k
Motherboard: ASRock Z87 Extreme 3
Heatsink: Cooler Master Seidon 240M
GPU: ASUS HD 7870 GHz Edition
RAM: GSKILL Sniper 8GB (2 x 4GB)
PSU: OCZ Fatal1ty 750W Modular
HDD: WD Blue 1TB
Optical Drive: LG Black 12x BD-ROM
Case: NZXT Phantom 410
Ivy-Bridge
CPU: Intel Core i7 3770k
Motherboard: ASROCK Z77 Extreme 6
GPU: Sapphire HD 7870
RAM: Corsair Vengeance 8GB (2 x 4GB)
PSU: Corsair CX750
HDD: WD Black 1TB
https://linustechtips.com/topic/25565-need-help-choosing-cpu/
IVB or SB.
https://linustechtips.com/topic/25565-need-help-choosing-cpu/#findComment-324546
Intel Xeon E3-1230 v3. It is literally a 4770 for the price of an 4670k.
Personal Build Project "Rained-On"
helped building up the CPU Overclocking Database and GPU Overclocking Database, check them out ;)
#KilledMyWife #MakeBombs #LinusIsNotFunny || Please, dont use non-default grey font colors. Think about the night-theme users! ;)
https://linustechtips.com/topic/25565-need-help-choosing-cpu/#findComment-324548
First rev haswell boards have USB3 bugs, since you plan to OC you'll probably get very nearly the same performance out of your 3770 anyway
So I would go with the 3770k at this time.
if you can wait for the next chipset rev that resolves the USB3, get haswell for the power saving features.
- Silverstone TJ08B-E - Gigabyte Z87M-D3H - i7 4770k @ 4.0GHZ 1.2v - 16gb Kingston HyperX Black 1600 - Gigabyte GTX 770 OC 4GB -
- Silverstone Fortress FT02 - MSI Z77 Mpower - i5 3570k @ 4.0GHZ 1.09v - 8gb Mushkin Blackline 1600 - MSI GTX 670 PE -
- Lenovo T430 (1600x900) - i5 3210m - 8GB DDR3 1333 - nVidia NVS5400M - 256GB mSATA OS - 320GB HDD-
https://linustechtips.com/topic/25565-need-help-choosing-cpu/#findComment-324550
apart from it's not unlocked and isn't clocked as high. OP wants to OC.
https://linustechtips.com/topic/25565-need-help-choosing-cpu/#findComment-324555
yeah, did not realize that in the first place, sry.
https://linustechtips.com/topic/25565-need-help-choosing-cpu/#findComment-324558
i will take that into consideration, also do you know if the wattage on the psu is good enough for the build?
https://linustechtips.com/topic/25565-need-help-choosing-cpu/#findComment-324664
So long as you're sticking with single GPU, 500W is just fine. I think AMD recommends 550 for all of their cards these days. Just get a good one. I suggest Seasonic.
https://linustechtips.com/topic/25565-need-help-choosing-cpu/#findComment-324671
A 3570k should be fine for gaming. Games aren't even that cpu demanding compared to the gpu. Get a 3570k and upgrade to a 7950 instead.
Also, 500w will be plenty for a 7870 and 600w for 7950.
https://linustechtips.com/topic/25565-need-help-choosing-cpu/#findComment-332416
