Screen wil not adjust
Go to solution Solved by Guest,
Nvidia
I have my computer plugged in on my 30 inch TV but when I turned it on the sides where cropped out how can I fix this (useing HDMI)
CPUFX 8320, Motherboard ASUS M5A78L-M/USB3 Socket AM3+ AMD, RAM g.skill ripjaws x series (2x8gb), GPUstrix gtx 970, Storage 500gb + 500gb + 250 ssd, PSU EVGA 600w B 80 PLUS BRONZE, Display(s) ASUS VG248QE 24"+ Hisense 24" + Vizio 24", Cooling Cooler Master Hyper 212 EVO, PC Part Picker  http://pcpartpicker.com/p/LFxQ23
https://linustechtips.com/topic/255449-screen-wil-not-adjust/
Go to control panel, search for underscan, set to 0%
RIG: I7-4790k @ 4.5GHz | MSI Z97S SLI Plus | 12GB Geil Dragon RAM 1333MHz | Gigabyte G1 Gaming GTX 970 (1550MHz core/7800MHz memory) @ +18mV(Maxed out at 1650/7800 so far) | Corsair RM750 | Samsung 840 EVO 120GB, 1TB Seagate Barracuda | Fractal Design Arc Midi R2 (Closed) | Sound Blaster Z        Getting: Noctua NH-D15 | Possible 250GB Samsung 850 Evo        Need a console killer that actually shits on every console? Here you go (No MIR/Promo)
This is why you should not get an FX CPU for ANY scenario other than rendering on a budget http://linustechtips.com/main/topic/286142-fx-8350-r9-290-psu-requirements/?p=3892901 http://linustechtips.com/main/topic/266481-an-issue-with-people-bashing-the-fx-cpus/?p=3620861
https://linustechtips.com/topic/255449-screen-wil-not-adjust/#findComment-3497829
Nvidia or AMD control panel.
Nvidia
https://linustechtips.com/topic/255449-screen-wil-not-adjust/#findComment-3497836
See if the TV has an auto adjust setting in the menu.
https://linustechtips.com/topic/255449-screen-wil-not-adjust/#findComment-3497838
I pushed detect and it did not work
https://linustechtips.com/topic/255449-screen-wil-not-adjust/#findComment-3497850
Nvidia
How does one get to that
https://linustechtips.com/topic/255449-screen-wil-not-adjust/#findComment-3497865
Nvidia control panel dude...
Face palm
https://linustechtips.com/topic/255449-screen-wil-not-adjust/#findComment-3497879
That did not work :(
https://linustechtips.com/topic/255449-screen-wil-not-adjust/#findComment-3497890
I have got it to work
https://linustechtips.com/topic/255449-screen-wil-not-adjust/#findComment-3497912
