#Hyper212EvoClub and a question
So i am getting a 212 evo but do i really need it if my mobo is shit and cant go over 4.5? With my current cooler (sig) i could hit 4.4 on 1.4~1,385V (dont remember with 4.5) and the temp was ~53*C. Atleast some people said me that my mobo isnt good for ocing with 4+1 power phrases. (SIG)
CPU: AMD FX 8350 | GPU: AMD R9 270 Windforce | MOBO: ASRock 990FX Extreme 3 | RAM: Kingston HyperX 8GB | Case: X Predator X1 |CPU COOLER: Hyper T4
NAZIS WILL RISE.
https://linustechtips.com/topic/255398-hyper212evoclub-and-a-question/
its not the best but not the worst, consider the raijintek themis or ereboss instead of the hyper 212, mounting it is such a hassle.
Listen if you care.
I wouldn't OC too much with an FX8. If you're happy with the noise right now, then just stick with the CNPS5X at 4.4
"Rawr XD"
My CNPS5X is broken. Underwolted with 4Ghz Temps goes to shit. But everybody says that the 8350 just need to be oc'ed.
NAZIS WILL RISE.
