I am looking to upgrade my CPU around xmas and would like some help.
Budget: $200 - 250ish US
Current Rig:
  • CPU: Core i3 2150
  • Mobo: Msi z68a-GD55
  • Ram: 8gb --1600Mhz
  • GPU: GTX 760
  • OS: Windows 7
  • cpu cooler: CM Hyper 212 EVO
  • Power Supply: XFX 750w
  • Disk drive: 120gb ssd, upgrading to 240 soon.
  • Monitor: 1 now, would like to upgrade to 2.
As you can see I am lacking at the CPU, not to bad though, only Arma3 gave me and real issues. But it is time to upgrade.
Use:
  • Moderate gaming
  • School and work
So here is my thoughts:
I could upgrade just the CPU to the 3570K.
Or I could swap out my mobo to a ASUS M5A97 R2.0 LE or better and put a AMD 8350.
If I switch to AMD, I maybe able to sell my current mobo, cpu and old gpu for a little bit and help me either get more/faster ram or a better mobo.
For some reason I have an itch to switch(busta rhyme) to AMD.
Any thoughts?
Much info
https://linustechtips.com/topic/255374-looking-for-upgrade-help/
get any i5 4xxx series and you will be fine. just do a bios update first.
Rigs I've Built
The Striker i5 4590 @ 3.7 ||  MSI GTX 980 Armor X2 || Corsair RMX 750 || Team Elite Plus 8 GB || Define S || MSI Z97S SLI Krait
The Office PC i3 4160 @ 3.6 || Intel 4600 || EVGA 500B || G.Skill 8 GB || Cooler Master N200 || ASRock H97M Pro4
The Friend PC G3258 @ 4.3 || Sapphire R9 280X Tri-X || EVGA 600B || 8 GB Dell Ram || Cooler Master N200 || ASRock H97M- iTX/ac
The Mom Gaming PC A10-7890K @ 4.4 || iGPU + ASUS R7 250 ||  8 GB Klevv DDR3-2800 Mhz
https://linustechtips.com/topic/255374-looking-for-upgrade-help/#findComment-3496860
Current Rig:
  • CPU: Core i3 2150
  • GPU: GTX 760
  • OS: Windows 7
Use:
  • Moderate gaming
  • School and work
Any thoughts?
repost
Please follow your topics guys, it's very important! CoC F.A.Q  Please use the corresponding PC part picker link for your country USA, UK, Canada, AustraliaSpain, Italy, New Zealand and Germany
also if you find anyone with this handle in games its most likely me so say hi
https://linustechtips.com/topic/255374-looking-for-upgrade-help/#findComment-3496862
The 8350's not worth it.
Get a 8320 if you're looking into AMD.
Also, with AMD's new CPU's on it's way, you might want to wait a little longer.
I personally recommend a 4690K. Is there any way you can stretch your budget to $300?
#SAMSUNG  "provided us 4 1tb ssds so we could run the whole site off solid state." - LinusTech
#GALAXY
#ATIV
https://linustechtips.com/topic/255374-looking-for-upgrade-help/#findComment-3496870
Current Rig:
  • CPU: Core i3 2150
  • GPU: GTX 760
  • OS: Windows 7
Use:
  • Moderate gaming
  • School and work
Any thoughts?
Just get and I5 2500K or an i7 26-2700k
https://linustechtips.com/topic/255374-looking-for-upgrade-help/#findComment-3496888
https://linustechtips.com/topic/255374-looking-for-upgrade-help/#findComment-3497018
CPU's for the most part don't fail, but make sure you buy form someone with a good buyer record and that they have a return policy
and make sure you(((((((((( READ the listing ))))))))) If it says it works and it gets to you and doesn't the seller has to give you your money back no matter what return policy or not.
https://linustechtips.com/topic/255374-looking-for-upgrade-help/#findComment-3497077
