Hello,
im planning some upgrades to my PC setup soon and would like to hear your toughts/suggestions
current setup:
CPU: intel i7 2600K (stock)
GPU: asus radeon hd 6950 direct cu ii (1gb, slight oc, asus direct cu )
MBO: asus P8P67 PRO (REV 3.1)
RAM: vengeance 8 gb (1600 mhz, 2X4gb)
HDD: WD caviar black 1 TB (mass storage)
SSD: kongstone hyperX 3k 240gb (OS)
PSU: corsair TX750 80 plus bronze
CPU cooler: corsair H80
CASE: HAF X (4x 200mm fan)
MONITORS: LG 20"(1650x1080), DELL 24"(1920x1080)
my plan is to upgrade to a LG 34UM95(3440x1440) and keep the 24" as a secondary monitor,im sure that  my curretn card won't be able to run this monitor very well for gaming so the plan is to upgrade the gpu to one of these:
1.)GTX 970 ---- (0/4 recommend)
2.)GTX 980 ---- (0/4 recommend)
3.)GTX 970 x2 ---- (4/4 recommend)
4.) something else suggest
my mbo supports sli and the psu should be enough to run the config,
the plan is to oc the cpu (hope around 4.2-4.4, will be my first time ocing so hoping nothing gets fried)
i mostly play mobas like LOL/strife... and mmos (Wildstar/GW2/Aion... and occasionally some more single player based games (AC...)
the system is also used for programing and some 3D modeling software
also very often i find that im using almoast all of my ram so im thinking of upgrading that too by adding 8gb more, the problem is i can't find the exact ram stick that i have in any store near me so im wondering:
1.)what are the pros/cons of putting a different pair of ram sticks to my existing ones (would still buy corsair ram)
while i think that the confing apart from the gpu is fine for what i need i would like to hear your toughts on it (is it worth to upgread this system...)
https://linustechtips.com/topic/255161-help-with-upgrade/
if you want amazing performace get those SLI 970.
CPU: Xeon 1230v3 - GPU: GTX 770  - SSD: 120GB 840 Evo - HDD: WD Blue 1TB - RAM: Ballistix 8GB - Case: CM N400 - PSU: CX 600M - Cooling: Cooler Master 212 Evo
Update Plans: Mini ITX this bitch
https://linustechtips.com/topic/255161-help-with-upgrade/#findComment-3494578
Those 2 970 and overclock them to get the performance of stock 980
this
My Main Build: NZXT S340 - NZXT Kraken X31 - Crucial MX100 256GB - i5 4460 - Gigabyte Z97P D3 - Kingston HyperX Red 8GB - MSI Nvidia GTX 780 3GB - Corsair LL & HD RGB Fans, Corsair Lighting Node Pro.
https://linustechtips.com/topic/255161-help-with-upgrade/#findComment-3496831
