Tips to fix stuck pixels?
I have two stuck pixels, a red one which after tapping the screen disappears for at least an hour and up to a week before showing back up, and a blue one which will NOT go away. I have tried pressure, pixel "exercisers", a hot towel in a plastic bag, and a combination of those but nothing. Anyone have any secret tricks or just any tricks that might fix these?
- i7-2600k @ 4.7GHz - MSI 1070 8GB Gaming X - ASUS Maximus V Formula AC3 Edition - 16GB G.SKILL Ripjaws @ 1600Mhz - Corsair RM1000 - 1TB 7200RPM Seagate HDD + 2TB 7200 HDD + 2x240GB M500 RAID 0 - Corsair 750D - Samsung PX2370 & ASUS ROG SWIFT -
https://linustechtips.com/topic/255032-tips-to-fix-stuck-pixels/
A new monitor :P
https://linustechtips.com/topic/255032-tips-to-fix-stuck-pixels/#findComment-3493131
A new monitor :P
LOL if this wasn't a brand new $800 monitor
https://linustechtips.com/topic/255032-tips-to-fix-stuck-pixels/#findComment-3493135
I heard of a way with a pencil, I think it said to take a dullish pencil and place it over the pixel, then lightly tap on it, though I'd google it to make sure of the correct way of doing it so you don't damage the screen.
https://linustechtips.com/topic/255032-tips-to-fix-stuck-pixels/#findComment-3493138
I tried the (capped) tip of a permanent marker, nothing
https://linustechtips.com/topic/255032-tips-to-fix-stuck-pixels/#findComment-3493144
What are the dead/stuck pixel requirements to RMA?
https://linustechtips.com/topic/255032-tips-to-fix-stuck-pixels/#findComment-3493159
Well its ASUS.... and their dead pixel policy is 3-5 pixels so I would assume the stuck is at least 3, which I have 2 -_-
https://linustechtips.com/topic/255032-tips-to-fix-stuck-pixels/#findComment-3493170
Well damn...
https://linustechtips.com/topic/255032-tips-to-fix-stuck-pixels/#findComment-3493176
Well damn...
IKR, its not super terrible since its the ROG SWIFT so its 1440p so they are pretty small, plus the red is the only one that is super noticeable, the blue is hard to see even on a dark grey background because it is muchhh darker than the red one which luckily goes away temporarily at least
https://linustechtips.com/topic/255032-tips-to-fix-stuck-pixels/#findComment-3493180
