Hi
When my new computer gets sold (Lol, New) i will quickly build a new one.
1.my budget is $500 is is flexible... and i live in Australia (Dang)
2.Mostly School Use so lots of word,excel power point and even video editing but not very often and the everyone and then Illuminati confirmed video for Facebook, not YouTube because i want to share it with friends not the world. and emulating, and some gaming.
3.i plan on running 3 Monitors at Home but only 1 when i go around.
4.ill use my windows 7 Os and i already have peripherals, actually i might trade my windows 7 for windows 8 at my local store.
5.I am getting this because i want a REALLY REALLY SMALL PC And I can easily carry it around,
Now the Main thing is that i want this too be small and easy to carry around.
You Can Go either way, AMD or Intel or Nvidia (for GPU if you decide to put one in)
Thanks In advance
Do not take life too seriously. You will never get out of it alive.
        :o
https://linustechtips.com/topic/254569-mini-itx-500-build/
ok so, $500 AU budget, monitor and keyboard, etx not needed, and OS is not needed.
What kind of gaming do you mean? like Minecraft, or CoD or any other AAA games
CPU: Intel Core i5 4460 | GPU: XFX r9 280x DD BLACK OC EDITION | RAM: 8gb Kingston HyperX Fury 1600Mhz | Mobo: Gigabyte h97n-WIFI | PSU: EVGA 600B | Case: Cooler Master Elite 120 | Cooler: Stock intel | SSD: Samsung 840 EVO 120gb | Storage: WD 150 gb
CPU: Intel Core i7 4710MQ | GPU: NVIDIA Geforce GTX 850M | RAM: 8gb Corsair 1600Mhz | Mobo: Metabox WA50SJ Motherboard | Case: Metabox WA50SJ case | Cooler: Stock | SSD: Sandisk 256gb
:wub:  :wub:  :wub:
Best purchase this year, bcuz forza
https://linustechtips.com/topic/254569-mini-itx-500-build/#findComment-3487199
I would recommend you use a pentium G3258 overclockable CPU with a cheap OCable mobo like a B81. Then shove that in a CM elite 110 and use a R7 260 ITX if that exists. My point is that the GPU needs to be very short to accommodate the 110's hella small space inside.
Edit: this is the case I'm talking about http://www.coolermaster.com/case/mini-itx-elite-series/elite110/
Follow the topics you create using the "Follow" button in the top right corner!
One day I will have my GTX 970. One day. PC specs are at my profile.
Not sure how to check what part works with what? Check out my compatibility guide!
https://linustechtips.com/topic/254569-mini-itx-500-build/#findComment-3487277
I play the latest games, at the moment far cry 4 and advanced warfare, dragon age inquistion and gta soon to come so yeah... latest games. sorry for late reply i was studying.
        :o
https://linustechtips.com/topic/254569-mini-itx-500-build/#findComment-3487303
It isn't the best, but meh, maybe if you could stretch you budget to $600 you could get a lot more out of it, but here is what I have so far:
https://www.pccasegear.com/index.php?main_page=wish_lists&wlcId=377785&action=wish_lists
:wub:  :wub:  :wub:
https://linustechtips.com/topic/254569-mini-itx-500-build/#findComment-3487306
@Krockendra This will be better for gaming and it is a little bit cheaper
:wub:  :wub:  :wub:
https://linustechtips.com/topic/254569-mini-itx-500-build/#findComment-3487314
