Upgrade help.
Solved by GeoffreyPope,
its an fx 6300. Hence the reason for the mobo upgrade.
Get the 970, you will not really notice the bottleneck - though there will be one to some degree. As you are already really limited by your GPU more than anything else the most cost effective upgrade would be the GPU and you can then see for yourself if you are happy with the performance increase and therefore if it is worth you upgrading the motherboard and processor. (changing the motherboard will give no performance gain and most games are more GPU restricted than CPU restricted. If it was a e4400 or something like that the processor upgrade would be more urgent - what are you even doing with a 270x.
The 6300 can hold its own)
