Extreme temps help!
Go to solution Solved by Archangel1994,
False readings. If the motherboard was 119C your PC would not be running
Hey guys
I've been getting some worrisome readings off of HWmonitor and speedfan saying my motherboard is 115c!! It's weird cause my case is cool as a cucumber along with all my other components (gpu 39c, cpu in the 20s) and I checked my bios and it said my mobo was at 31c... should I be worried or are these false readings?
https://linustechtips.com/topic/253804-extreme-temps-help/
RIG: I7-4790k @ 4.5GHz | MSI Z97S SLI Plus | 12GB Geil Dragon RAM 1333MHz | Gigabyte G1 Gaming GTX 970 (1550MHz core/7800MHz memory) @ +18mV(Maxed out at 1650/7800 so far) | Corsair RM750 | Samsung 840 EVO 120GB, 1TB Seagate Barracuda | Fractal Design Arc Midi R2 (Closed) | Sound Blaster Z        Getting: Noctua NH-D15 | Possible 250GB Samsung 850 Evo        Need a console killer that actually shits on every console? Here you go (No MIR/Promo)
This is why you should not get an FX CPU for ANY scenario other than rendering on a budget http://linustechtips.com/main/topic/286142-fx-8350-r9-290-psu-requirements/?p=3892901 http://linustechtips.com/main/topic/266481-an-issue-with-people-bashing-the-fx-cpus/?p=3620861
https://linustechtips.com/topic/253804-extreme-temps-help/#findComment-3476932
What program you use to check the temps?Beside at that temp it would shut down itself
Beware of him that is slow to anger; for when it is long coming, it is the stronger when it comes, and the longer kept. Abused patience turns to fury.
https://linustechtips.com/topic/253804-extreme-temps-help/#findComment-3476934
119C and your PC would run out of his Case :)
CPU: Xeon 1230v3 - GPU: GTX 770  - SSD: 120GB 840 Evo - HDD: WD Blue 1TB - RAM: Ballistix 8GB - Case: CM N400 - PSU: CX 600M - Cooling: Cooler Master 212 Evo
Update Plans: Mini ITX this bitch
https://linustechtips.com/topic/253804-extreme-temps-help/#findComment-3476959
lol unless he has that death virus. it hacks your BIOS disables all the temp sensors and then starts a bit coin miner. I have seen in person a MELTED cpu socket in a AMD Semprom. Its bad, although i think a windows update patched that
My Car: http://linustechtips.com/main/topic/274320-the-long-awaited-car-thread/?p=4442206
CPU: i5 4590 |Motherboard: ASRock H97M PRO4|Memory: Corsair Vengance 8gbs|Storage: WD Caviar Blue 1TB|GPU: ZOTAC GTX 760 2gb|PSU: Thermaltech TR2 500W|Monitors: LG24M35 24" & Dual 19"|Mouse:Razer DeathAdder 2013 with SteelSeries Qck mini|Keyboard: Ducky DK2087 Zero MX Red|Headset: HyperX Cloud|Cooling: Corsair 120mm blue LED, Lepa vortex 120mm, stock 120mm|Case:Enermax Ostrog Blue Windowed
https://linustechtips.com/topic/253804-extreme-temps-help/#findComment-3476988
