Which graphics card would be better for my build?
Solved by Aniallation,
Hey guys,
Im putting together a build for 1600 AUD and am stuck on a decision about a graphics card. Which one would be better for my build?
The two graphics cards are the ASUS GeForce GTX 970 Strix DirectCU II 4GB and the Gigabyte GeForce GTX 970 G1 Gaming 4GB.
Hands down Gigabyte G1. There's no debate, it's the best 970 to get. From the cooler to the actual GPU chip itself, everything about it is better then the STRIX, apart from the useless fans-turn-off feature, because the G1 will still be inaudible at low loads when it's in your case.
