Help me buy a fan controller!
I am currently relying on my ASRock FANtastic tuning software (which means I have about 5 fans connected to one header), and while it works alright, I would like to be able to have precise control over each fan. This is my current fan setup:
Rear: 120mm stock Corsair fan
Top: Currently nothing, looking to get 2x140mm
Front: 2x120mm Corsair AF Performance fans
Bottom: Currently a radiator for my GPU (which I will be replacing with a 970 soon), but possibly a 140mm led fan.
What fan controller would you recommend? I will be sticking with the Corsair Master Race fans, so 3 pin. Ease of use would be great. 6 fans total, for a total of 4 different channels (2x top, 2x front, 1x rear, 1x floor).
As a side note, I tried a Sentry mesh a while ago and it makes the fans buzz anywhere that's not lowest or highest setting.
The Grey Squirrel
CPU: i7-6700k @ 4.8GHz - CPU Cooler: Be Quiet! Dark Rock 3 - Motherboard: ASUS Z170-E - GPU:  ASUS GTX 1060 DUAL
Case: Inwin 303 - RAM: 4x8GB Corsair LPX Storage: 2x Samsung 850 EVO 500GB - PSU: EVGA SuperNOVA G2 550W
Mouse: Logitech G502 Wired / Bungee Keyboard: Corsair Strafe Cherry MX Red Headphone: Sony MDR- 1R
Microphone:  Blue Yeti - Webcam: Logitech C920 - Monitors: 3x Dell S2415H
https://linustechtips.com/topic/252999-help-me-buy-a-fan-controller/
I could also use a suggestion on this as well. My motherboard doesn't support integrated controller and I haven't had great luck with 3rd party software. Half of my fans are running at like max RPM so shit gets kinda loud...
Current PC build: [CPU: Intel i7 8700k] [GPU: GTX 1070 Asus ROG Strix] [Ram: Corsair LPX 32GB 3000MHz] [Mobo: Asus Prime Z370-A] [SSD: Samsung 970 EVO 500GB primary + Samsung 860 Evo 1TB secondary] [PSU: EVGA SuperNova G2 750w 80plus] [Monitors: Dual Dell Ultrasharp U2718Qs, 4k IPS] [Case: Fractal Design R5]
NZXT Sentry 3 is amazing
RIG: I7-4790k @ 4.5GHz | MSI Z97S SLI Plus | 12GB Geil Dragon RAM 1333MHz | Gigabyte G1 Gaming GTX 970 (1550MHz core/7800MHz memory) @ +18mV(Maxed out at 1650/7800 so far) | Corsair RM750 | Samsung 840 EVO 120GB, 1TB Seagate Barracuda | Fractal Design Arc Midi R2 (Closed) | Sound Blaster Z        Getting: Noctua NH-D15 | Possible 250GB Samsung 850 Evo        Need a console killer that actually shits on every console? Here you go (No MIR/Promo)
This is why you should not get an FX CPU for ANY scenario other than rendering on a budget http://linustechtips.com/main/topic/286142-fx-8350-r9-290-psu-requirements/?p=3892901 http://linustechtips.com/main/topic/266481-an-issue-with-people-bashing-the-fx-cpus/?p=3620861
Get a manual control (like with analog controlls, turning knobs etc.) with 5 channels and group some fans together using Y-Splitters (same fans with same fans obviously). If you want something with a digital control, use your motherboard with splitters or get something proper like a Grid+. No in between solutions like ht eBitfenix Recon, that thing is awful!
who cares...
Do you want to control them through the front panel or software? NZXT's Grid+ is fairly good for software control.
Grid+  Good option
Grid+  review for Linus
Grid+ is a great unit with terrible software.
I second this. Good option :D  :D  :D
Looks interesting: http://www.amazon.com/NZXT-Technologies-5-4-Inch-Controller-AC-SEN-3-B1/dp/B00KJGYLNM/ref=sr_1_1?s=electronics&ie=UTF8&qid=1416324317&sr=1-1&keywords=nzxt+sentry+3
Do you guys have any person experience them them? And possibly with corsair fans?
And I found this, possibility overkill: http://www.corsair.com/en/corsair-commander-mini
The Grey Squirrel
Corsair's Link stuff is good and has loads of functionality, but is kind of a waste for just controlling fans. Only really worth it if you have a load of Corsair's "i" products.
Until recently I used one of Akasa's controllers (AK-FC-08BKV2). It's simple, but it works. You can control up to 6 sets of fans, with the ability to completely turn them off. It's clean looking too.
Alaska tends to be more expensive than I would like it to be. I don't have any corsair compatible products and might only get a 100i, but that's an unnecessary expense.
The Grey Squirrel
