Currently have 2 sets of duel channel RAM slots on my Motherboard.
Current RAM installed: 2x4 Gb 1600
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231314
RAM looking to add: 2x 8gb 1866
http://m.newegg.com/Product/index?itemnumber=N82E16820104461&nm_mc=KNC-GoogleAdwords-Mobile&cm_mmc=KNC-GoogleAdwords-Mobile-_-pla-_-Desktop+Memory-_-N82E16820104461&gclid=CMSy6YPEgsICFchlfgodak0Arg
Was wondering with all 4 sticks installed if this ram would work together or do i need to follow the rules of only install the exact same ram together
If you need more information please let me know. I appreciate your time. Tartan
https://linustechtips.com/topic/252557-adding-ram-need-a-little-help/
They should work but you will only be able to use all the ram at 1600 and the lowest latency.
