Connnection issue with friend
A bit of background info would help such as:
How are you connected? I'm assuming not LAN?
Which game?
Specs?
What all have you tried so far?
System/Server Administrator - Networking - Storage - Virtualization - Scripting - Applications
How would i go about doing that?
Find the brand and model of your router, it's usually printed on the back or underside of it. Then go to http://portforward.com/english/routers/port_forwarding/ and follow the instructions, simple as that.
If the game you are playing is not listed on there, I suggest a quick trip to google, it should have all the relevant information.
