Which Power Supply?
Thanks everyone. Seems Seasonic is very well regarded, even if their website isn't really informative.
Thanks for the suggestion SeanBond but I'm not really looking to get it shipped from the US due to the shipping time and any potential warranty issues. The ones I listed in the first post are all available from Mwave (mwave.com.au) which is only a 15 minute drive from my house. Appreciate it though!
Going by WoodenMarker's comments, I might even try to save a little more and get a 550W, which makes it about $120 AUD.
Seasonic G Series 550W or Corsair CS550M 550W?
Both are modular/semi modular which are both good enough for me as I just don't want unused cables inside my case. Supplied cables will do everything I need them to...
Both are about the same price as well!
Leaning towards Seasonic at the moment...
EDIT:
I've never heard of that brand before...but it's even cheaper than the Seasonic G 550W and Corsair CS550M. It's 80+ Gold and modular as well...might need to add that to the list!
The Corsair CS 550M is ok. The build quality of it is inferior to both the Super Flower Golden Green and Seasonic G. Since both of them are $120 AUD, I would go with the Seasonic G. I'm going to assume that the shipping cost of the SF GG 600w I had mentioned will bring it around the same price as the Seasonic G, as such, I would just recommend going for the Seasonic (easier to deal with returns if anything comes up).
The XTR 650w may still be an option and is indeed better than the Seasonic G, if you want something quiet and fully modular. The 100 extra watts can be consider to be an added value, but like already stated, it's overkill.
The B2 or G2?
Not sure of the difference between Bronze and Gold to be honest, I just wanted something that was definitely going to be very reliable for a good while.
EVGA Supernova 750w G2 is an excellent high-end PSU. While it is better than everything mentioned so far, it's $145 AUD, and you aren't going to SLI.
As for the B2, it's essentially a cost down version of the Super Flower Golden Green unit (like the Rosewill Capstone that had been mentioned). It's a good PSU, if you get a good deal on it, but as already noted, it's overkill if you aren't going to SLI.
Bronze vs Gold is about efficiency. Basically, how much energy is being wasted as heat during the AC-DC conversion of the power supply. It might have an affect on your electricity bill (usually very small depending on how much electricity cost) as well as how hot the PSU can get. It however doesn't necessary correlate to better internal components.
