Help deciding between CPUs please!
Get the 8350 and the mobo. I would say H100i though for this as it is AMD (the're products tend to heat up quite a bit). Note: You will need an external GPU for windows as it requires direct x 9.0c for 7. IF it is not for gaming then get an AMD Radeon R7 250.
A 4790 (non-K) with no cooler and an h81 board will outperform an 8350 and be about the same price; or he could even go with a Xeon 1231v3 on an h81 board and he'll outperform an 8350 and be about $80~ cheaper. And he could still go with a 1231V3 on an h97 board (with XFIRE support) and still be about $50 cheaper.
So even tho its water cooling vs. air cooling I wont see much difference? So its just better to go with the cheaper option then.
And the CPU i chose is unlocked right? All these people kept saying that is was locked? I thought the K on the end ment it could be Oc'd?
Edit: The cooler said it only fits Intel LGA2011, would it still fit LGA 1150?
Well, watercooling isn't automatically better than air cooling. Its not until you get to a 240mm radiator (or a thick 120) that you start to benefit from water cooling. So, an H80i, or NZXT Kraken X41 would be the lowest I'd go for an AIO. The cooler will fit on LGA 1150.
The 4690k is overclockable; you misread what they were saying, they were saying that A locked i5 is better than an 8350 (in gaming), therefore an unlocked i5 would be even better.
But as I said earlier, you should get your priorities straight. If editing/rendering is more important to you than gaming, then I'd go with an Intel Xeon 1231v3 on an H97 board that supports crossfire; if gaming is more important, then I'd go with a 4690k on a Z97 board.
