INTEL CORE i5-7600K | ASUS ROG STRIX B250i GAMING | CRUCIAL BALLISTIX SPORT LT 16GB | EVGA GTX 970 SC | EVGA B3 550W
SAMSUNG 850 EVO 250GB | CRYORIG M9i | BE QUIET! PURE WINGS 2| FRACTAL DESIGN DEFINE NANO S
https://linustechtips.com/topic/251463-side-panel/#findComment-3446822
So I have a Fractal Design Arc midi R2 case with solid side panel, but I really want a windowed one.Do you know any place where I can get only a windowed side panel alone?(preferably europian place)
Have you called Fractal yet :P
https://linustechtips.com/topic/251463-side-panel/#findComment-3447679
Oh thats great to know!Actually I'm from hungary, so the website you sent me is local.It says Define R4 and Arc Mini.Is it a mispell (I think it is), because the Arc mini is much smaller than an R4 right?
https://linustechtips.com/topic/251463-side-panel/#findComment-3449968
I'm really not sure now, Fractal doesn't list a side panel for the Mini's as far as I can tell, and the product ID all the retailers in Hungary use is FD-AC-WND-DEFR4-ARC-BL instead of the one Fractal lists as correct for the panel you need, FD-AC-WND-DEF4-ARC-BL. Note the bold R in the first one. But 270mm x 290mm doesn't work out properly for the Mini's dimensions, it does however match the window dimensions on the Midi sized cases.
I would say contact Fractal, they should have a much better idea of things, and hell, they might even send you one for free.
https://linustechtips.com/topic/251463-side-panel/#findComment-3451957
Thanks for the suggestion, I contacted Fractal and now I'm waiting for their response.I also checked the dimensions of the panel on PCX's and Fractal's site and they are identical.(I mean the Midi R2 on Fractal's site) I'll report whenever I know something more. :D
https://linustechtips.com/topic/251463-side-panel/#findComment-3453208
