Graphics card advice
Solved by Thorium19,
Have a look at the GTX 760, at the moment they've been dropping in price quite significantly, are a bit better in performance than the 270X and are only a bit more expensive. You can probably get one for about €170/180 at the moment, as the equivelant UK price is around £150.
Issac Zachary ·
Posted in Troubleshooting1 -
4
PopsicleHustler ·
Posted in Audio4 -
4
4
Greasy_Pudding ·
Sveeno ·
Posted in LTT Releases8 -
4
thrasher_565 ·
Posted in Hot Deals0 -
6
play_circle_filled
Latest From ShortCircuit:
