Need Advice on Custom CPU Loop
Solved by Altecice,
Looks fine but change the fans. also 3 meters of tubing is quite a lot just cut more than what you need as you can always shorten the length later. Also just a heads up. DONT use anything over Prime95 version 26.6 when testing a 4790k they overheat. Also if your going to OC then 1.32 is about the max vcore for 24/7 use.
Issac Zachary ·
Posted in Troubleshooting5 -
4
PopsicleHustler ·
Posted in Audio4 -
4
4
Greasy_Pudding ·
Posted in Servers, NAS, and Home Lab3 -
Sveeno ·
Posted in LTT Releases8 -
4
thrasher_565 ·
Posted in Hot Deals0
play_circle_filled
Latest From ShortCircuit:
