I need a game capture card with can record at 1080p 60 FPS.
I was going for  Aver Media's LGP Lite or the normal LGP.
It's for recording on a PC by the way, since fraps has a crazy file size when recording.
I was looking at the elgato hd60 (tell me if it's good or something :D)
I will be playing FPS, racing, TPS, RPG, etc
Rorossi FTW!! :D
https://linustechtips.com/topic/251122-help-with-game-capture-cards/
Have you not already youtube searched Elgato 60fps capture reviews?
LGP doesn't do 1080p/60fps,........... but 720p/60fps and 1080p/30fps.
Although I've been doing 720p@60fps and upscaling it for 1080p/60fps youtube, and it isn't that noticeable because of youtube compression anyway. But If you were to do local HDD playback,  you'd definitely notice however.
Maximums - Asus Z97-K /w i5 4690 Bclk @106.9Mhz * x39 = 4.17Ghz, 8GB of 2600Mhz DDR3,.. Gigabyte GTX970 G1-Gaming @ 1550Mhz
i did do some research, and these were the two i selected, but i needed more help, so i came here
Fair enough, was only asking... and I can't speak for the elgato, but as stated, thats my experience with the LGP.
BTW - you'll get told this eventually, quote/like someone's post for the website to notify them of a reply, otherwise I'd not have known you did reply.
lol, thanks for the tip bro :D
do you happen to know any good external dvd drives since my case doesn't have a slot for it and i have a few games on disk and i pre-ordered a few collector's edition games so more disks :P so i need something to install em with
Rorossi FTW!! :D
External USB DVD drives are fine, and usually cheap enough $30
do you know any? make? model?
Not really, It's not something many people keep up to date on.
As long as it's got a decent write speed of 6-8x or higher, the better.
This is the one I have - http://www.msy.com.au/sa/elizabeth/pc-components/9863-samsung-se-208db-tsbs-external-slim-size-usb-dvd-rw.html
2x USB ports (One for Power + Operation at low burning speeds) But using included cables (having two connections for USB) it writes at a faster speed using both than using the one USB port.
thanks :D
Rorossi FTW!! :D
I know my favourite Youtuber uses an Elgato Gamecapture HD, which if I had to buy one looks like the one I'd probably pick. You can see his review thing here:
https://www.youtube.com/watch?v=vWHR-PjXa3A
CPU: Intel Core i7-4770k | Mobo: MSI Mpower Max | Cooling: Cryorig R1 Ultimate w/ XT140 front Fan | GPU: EVGA GTX 770 Dual SC SLI | Case: NZXT H440 | Case Fans: Phanteks PH-140SP x5 | PSU: EVGA Supernova P2 1000W | RAM: 16GB Crucial Ballistix Tactical Tracer | SSD: Kingston HyperX 3k 120GB | HDD: Seagate Barracude
Keyboard: Razer Blackwidow Ultimate 2013 | Mouse: Razer Deathadder 2013 | Headphones: Sennheiser HD438s | Mousepad: Razer Goliathus Control | Monitor 1: Benq XL2430T | Monitor 2: BenQ RL2455HM
