Yeh look pretty sweet. Ya gut bundle the cables together and make it look better.
FX8120 @ 5.0GHz | Sabertooth 990FX | Patriot Viper Xtreme 8GB @ 2133MHz | Powercolor HD7950 @ 1300/1800 | Bitfenix Shinobi XL Modded | Corsair AX850 | Mushkin 120GB & Seagate 2TB | Bitfenix Recon | 5X SP120 PE | 6X Yate Loon 120mm HS
Koolance 200 Res | 2X Koolance 360 Rads | Danger Den CPX Pro | EK 7950 Block | Koolance CPU Block | Bitspower & XSPC Fittings
Green Machine
https://linustechtips.com/topic/25057-redone-cable-management/#findComment-317571
What do you mean? Behind the motherboard tray?
No, you can just see that you have run the cables closer to gather and it make it look a lot cleaner.
Green Machine
https://linustechtips.com/topic/25057-redone-cable-management/#findComment-317583
I'm still not sure what you mean, perhaps if it's not too much trouble you could edit one of my pictures in a way that would show me what you mean were I to see it.
Looks great! I really haven't put in the time to focus on cables behind the motherboard tray, but I should probably do that eventually...
Thanks. The management behind my motherboard try was pretty poor beforehand. I like the way it turned out.
https://linustechtips.com/topic/25057-redone-cable-management/#findComment-317607
Sure, I think he means to bundle up the cables behind the motherboard tray, instead of having them in separate bundles. Something like at 3:46 of this video:
https://linustechtips.com/topic/25057-redone-cable-management/#findComment-317611
It looks tidier, but pretty much the same, lol.
Come and join the awesome Official LTT Star Citizen Org at LTT Conglomerat,  GTA 5 LTT Crew at LTT Conglomarate
PC Specs - 4770k - OC 4.5GHz  - GTX 780 SC - 16GB HyperX - NZXT H440 White - Corsair H100i - Corsair AX750 - Samsung Evo 250GB - 2 x PA238Q - ATH-M50 -
https://linustechtips.com/topic/25057-redone-cable-management/#findComment-317716
Yeah not too much changed, I just figured I'd post it on here to see what people had to say.
i love your display pic! howd you do it? great build btw
Thanks!
It's a .gif version of a very short YouTube video that I found one day. I used some site to create the .gif file. If only I could find the video again; I've tried and failed at least twice.
https://linustechtips.com/topic/25057-redone-cable-management/#findComment-319429
