Fan Controller question, HELP!
Solved by Aniallation,
Will the 10w one be enough to push my fans to their full potential if they need to be? And also if i push too many watts to my fans, can something be damaged?
0.1A means voltage times 0.1 will be wattage. At 7V fan will draw 0.7W, at 12V it will draw 1.2W.
10W will be enough to run 8 of them at 12V.
Watts only means how much power the fan will consume when running, you can't "push too many watts" to a fan.
