Need help with general math.
So, lets say the formula for power on a capacitor is:
Wc = 1/2 * C * U2
Its easy to calculate, easy to do.
But, HOW much is C when i have U and Wc? How do i get that formula?
How much is U when i have C and Wc?
Please help, im stuck, always on this stupid thing.
Primary: Lenovo T61 / Intel Core2Duo T7200 @ 2.2GHz / 3GB DDR2 / NVIDIA Quadro NVS 140M / Fedora 22 <<<< THE WHITE KNIGHT
Secondary: Compaq Presario CQ56 / AMD V130 @ 2.3GHz / 2GB DDR3 / AMD Radeon HD 4250 / Windows 8.1 <<< THE FORGOTTEN HERO
https://linustechtips.com/topic/249262-need-help-with-general-math/
2Wc divided by U2
Just a matter of getting C on one side of the equation by itself.
Edit:
Unless the 1/2 is only used with C and not C and U2.
Then you would end up with 2Wc divided by 2U2
Just remember, what you do to one side of the equation, you must do the same to the other.
Edit:
I'll put in a snip of a Word document so you have a visual representation and working.
CPU: Intel i7 8700K | CPU Cooler: be quiet! Dark Rock Pro 3 | RAM: Kingston HyperX 2x8GB | Motherboard: Asus ROG Z370-E | GPU: MSI GTX 970 | HDD: Seagate Barracuda 1TB & 2TB | SSD: Samsung 840 EVO 250GB & 970 EVO M.2 500GB | Case: Phanteks Enthoo Evolv X | PSU: Silverstone Platinum Strider 1100W | Monitor: AOC i2367Fh | Headphones: ATH-M40X | Mic: Antlion ModMic 4 | Keyboard: Corsair K70 RGB w/ MX Browns | Mouse: Logitech G502 HERO
Make sure you quote or mention the person you're replying to in your comment. Also remember to follow your thread when creating it to get a notification every time someone replies.
Be nice and have fun. Cheers!
2Wc divided by U2
Edit:
And when i need U2 then its 2Wc/C?
It's so easy...
You just take the things you don't need to the other side.
Wc= 1/2 * c * u^2
Wc/(1/2*u^2) = c
WC/1/2 = 2WC
so :
2WC/u^2 = c
U = sqrt(2WC/C)
It's so easy...
Wc= 1/2 * c * u^2
Wc/(1/2*u^2) = c
WC/1/2 = 2WC
so :
2WC/u^2 = c
U = sqrt(2WC/C)
Thank you so much! So much screwed up caclculations based on stupid formulas and me messing stuff up...
i luv u <33
Yes, but you'd have to square root the 2Wc/C to get the value of U, instead of U x U.
Just like to ask, is the 'x 1/2' only for the C or the U2 as well?
1/2 is only for C
-erm, I think I went full derp again-
Sorry I took so long, Imgur was being a derp.
1/2 is only for C
Than it's all g, Idk why but I think I went full derp there, having the 1/2 with the C exclusively, or with both the C and U2 wouldn't change anything lol.
Derping is awsome yeha lol :D
Thanks again!
