Put something small under the laptop's feet like jenga blocks or highlighters, it's likely that it's hardly getting air so when the GPU usage goes up it can't cool it adequately.
Mein Führer... I CAN WALK !!
https://linustechtips.com/topic/249164-passive-laptop-cooling/#findComment-3417424
i have plenty of space under it, didnt work
well I would look from something that isnt passive then.
I think linus showed off a laptop stand awhile ago with a 180mm fan in it.
On a side note maybe look at cracking it open to see if there's no dust in it, maybe swap the thermal compound too.
Its all about those volumetric clouds
https://linustechtips.com/topic/249164-passive-laptop-cooling/#findComment-3417482
He ain't cracking a MacBook up...
CPU: Intel i5 4570 | Cooler: Cooler Master TPC 812 | Motherboard: ASUS H87M-PRO | RAM: G.Skill 16GB (4x4GB) @ 1600MHZ | Storage: OCZ ARC 100 480GB, WD Caviar Black 2TB, Caviar Blue 1TB | GPU: Gigabyte GTX 970 | ODD: ASUS BC-12D2HT BR Reader | PSU: Cooler Master V650 | Display: LG IPS234 | Keyboard: Logitech G710+ | Mouse: Logitech G602 | Audio: Logitech Z506 & Audio Technica M50X | My machine: https://nz.pcpartpicker.com/b/JoJ
https://linustechtips.com/topic/249164-passive-laptop-cooling/#findComment-3417609
Compressed air or one of these guys ought to do the trick.
I don't know about Mac's, but you can throttle the CPU in windows, maybe there's a setting for it in Yosemite, that should lower temps.
100c is way too hot.
Currently I'm using DVD cases/ bottle caps/erasers to prop up my Y50, seems to do the trick, apart from a monthly cleaning.
Basically dust is the enemy, you can try taking it to an Apple store and ask them to clean it for you, these things get clogged like hell.
I would not touch the rMBP unless I had a spare kit of replacement screws and a high quality screwdriver along with an Anti static band.
Y50
4710HQ + GTX 860M 4GB vRAM + 8GB DDR3L + Peasantry 1080p + EVO840 250GB
https://linustechtips.com/topic/249164-passive-laptop-cooling/#findComment-3422112
