Hi,
I want to buy one or 2 white LED strips for my Define R4
Could anyone recommend me any? I am mostly looking for even distribution of the light so that there aren't any obvious brighter light spots.
Thanks
i think the bitfenix alchemys are pretty good.
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/24910-best-white-led-strips/#findComment-315442
I've heard alchemy are the way to go as well.
- Silverstone TJ08B-E - Gigabyte Z87M-D3H - i7 4770k @ 4.0GHZ 1.2v - 16gb Kingston HyperX Black 1600 - Gigabyte GTX 770 OC 4GB -
- Silverstone Fortress FT02 - MSI Z77 Mpower - i5 3570k @ 4.0GHZ 1.09v - 8gb Mushkin Blackline 1600 - MSI GTX 670 PE -
- Lenovo T430 (1600x900) - i5 3210m - 8GB DDR3 1333 - nVidia NVS5400M - 256GB mSATA OS - 320GB HDD-
https://linustechtips.com/topic/24910-best-white-led-strips/#findComment-315514
When it comes to white light I dont like neither NZXT or BitFenix because they have a blue tint.
I'd recommend Phobya Warm White:
A lot more natural!
In case the moderators do not ban me as requested, this is a notice that I have left and am not coming back.
https://linustechtips.com/topic/24910-best-white-led-strips/#findComment-315523
Check out the "IceModZ" LED- Strips.. Linus mentioned them some time ago and he think they are jsut amazin.. they also look pretty good, and you get em in length and color you want!
http://www.icemodz.com/led-strips.html
Little sneak Peak:
CPU: Intel i7 4790K @4.8GhZ  CPU Cooler: Be Quiet! Dark Rock Pro 2  Motherboard: Gigabyte Z97 UD3H  GPU: Asus ROG RX 480 8G OC Memory: 32GB Gskill Ares 2400Mhz  Storage: 2x Crucial M4 512GB SSD (raid0)  / 1TB Seagate FireCuda SSHD Case: Phanteks Enthoo Evolv ATX PSU: EVGA SuperNOVA P2 750W  Operating System: Windows 10 Enterprise LTSB (64 bit) Other: NZXT Hue+ LED Controller with 8 LED Strips for desk and PC lighting
https://linustechtips.com/topic/24910-best-white-led-strips/#findComment-315747
Currently using the blue bitfenix alchemy strips and they are awesome.
You can also connect or remove some if you have too little or too much.
CPU: Intel 2700k (4.7) MOBO: Asus P8Z77-V DELUXE GPU: Sapphire Vapor-X R9 290X RAM: 16GB Corsair Vengence (1866) CPU Cooler: Corsair H100i w/ 2x Noctua NF-F12 Storage: 256GB Samsung 830 Pro SSD (Boot), 64GB Crucial M4 (SSD Cache), 1TB WD Black Cavier, 2TB Hitachi, 2.5TB Buffalo Sound Card: Xonar Essence STX Case: Corsair Graphite 600t w/ full acrylic side PSU: Corsair HX750 (individually sleeved)
Peripherals: Filco Keyboard (Brown) Razer Deathadder, Sennheiser HD595, Zalman ZM-MIC1, Steelseries Qck Mass mousepad.
Pics of my Rig
https://linustechtips.com/topic/24910-best-white-led-strips/#findComment-318040
Really depends on the color of your build, I used the bitfenix alchemy white LED because my build is of warm color - the light blue create a rather natural white to it.
hope that helps :)
Check out the build: Used to be Obot, now Lilith
Shameless: Me
https://linustechtips.com/topic/24910-best-white-led-strips/#findComment-318167
Dont forget.. the Icemodz are some kind of modular, if you can solder :) They are also damn bright, and Linus loves them.. So your build log would probably get into the Livestream
https://linustechtips.com/topic/24910-best-white-led-strips/#findComment-322076
So. I have purchased an Icemodz and a bitfenix alchemy white LED strip and both arrived today and I have to say the Icemodz is far superior.
The cable sleeving on it is excellent, can not see the colour of the wires at all, the PCB the LED's are on is black which is a change from the time Linus first reviewed these (for the better), and yes, they're very very bright, very very nice, and...wait for it... very very high quality :P
https://linustechtips.com/topic/24910-best-white-led-strips/#findComment-333829
Take some pictures when you are done :) Linus would be damn happy bout this
https://linustechtips.com/topic/24910-best-white-led-strips/#findComment-333850
I just bought a 5m strip of white LEDs off ebay. They seem to be exactly like the Icemodz ones. I am just going to cut them up and connect them in series so i can have them around the case, then hook em up to a 3 pin fan connector and plug them into a Bitfenix Recon fan controller. Now i've just got to wait for them to arrive...
https://linustechtips.com/topic/24910-best-white-led-strips/#findComment-335626
