I just started my new build everything was going good and when i boot it for the first time, i get code 20 on my post LED. Of course i look up online and found it was a problem with a bios update with my board that it needed to support my 4790K. So i go and find another processor first i try a G1820 and i get the same result and now i recently tried a G3220 and i keep getting the same problems.  I already sent a support ticket to gigabyte but they take to long to respond. So if anybody can help me with this it would be very much appreciated.
https://linustechtips.com/topic/248787-gigabyte-post-code-20/
What board is it?
Gigabyte GA-Z97X-SOC
https://linustechtips.com/topic/248787-gigabyte-post-code-20/#findComment-3411886
"Dear Babxbba,
If the current BIOS is F2, the computer will not boot with 4790K installed. If you have other CPU compatible with F2, please change a CPU and update the BIOS to F5 before using 4790K. Thank you for your cooperation.
Regards,
GIGABYTE"
This is what I got from a search on the internet but it was not for the same cpu and mobo but it was Gigabyte related.
Here is the link ...
http://www.overclockers.com/forums/showthread.php/750534-GIGABYTE-GAMING-GT-Z97-no-post-or-boot-led-error-code-quot-20-quot
It was also mentioned in this thread that a post code 20 to 23 can be a memory/memory controller issue.
Too many ****ing games!  Back log 4 life! :S
https://linustechtips.com/topic/248787-gigabyte-post-code-20/#findComment-3411901
"Dear Babxbba,
Regards,
GIGABYTE"
Alright do you know what supported CPUs are compatible with F2?
https://linustechtips.com/topic/248787-gigabyte-post-code-20/#findComment-3411909
CPU support list on the manufacturer's website
Specs: CPU: AMD FX 6300 Motherboard: Gigabyte 970A DS3P RAM: HyperX Fury 16GB 1866MHz GPU: MSI R9 270 OC edition Case: Sharkoon VS3-S SSD: Samsung 840 EVO 120GB HDD: 1TB Caviar Blue PSU: Corsair CX500W
*If I say something that seems offensive, please don't take it seriously, it was most likely meant as a joke/sarcastically*
https://linustechtips.com/topic/248787-gigabyte-post-code-20/#findComment-3411938
https://linustechtips.com/topic/248787-gigabyte-post-code-20/#findComment-3411974
Did you look at the link then that I provided that showed F2 cpus for your board?
https://linustechtips.com/topic/248787-gigabyte-post-code-20/#findComment-3412040
yeah i saw that's for SOC Force
http://www.cpu-upgrade.com/mb-Gigabyte/GA-Z97X-SOC(rev._1.0).html
That link is for SOC not the Force and it says that i need F3
https://linustechtips.com/topic/248787-gigabyte-post-code-20/#findComment-3412076
  • 1 year later...
Did you ever fix this or did you have to RMA your mobo?
https://linustechtips.com/topic/248787-gigabyte-post-code-20/#findComment-7663581
