A quick question. I have a backup 480 watt power supply while I research a 700+ watt replacement. Does the I5 3570k need more than one of the 4 plug CPU power plugs on the motherboard? I had 2x the 4 pin power connectors on my dead power supply. I had both of them plugged in on my 3570k. I checked on my backup system that has only one 4pin CPU power plug on a Q6600 quad core.
I want to make sure my time is not wasted on an old power supply that I hope will work for up to 1 week.
https://linustechtips.com/topic/248628-power-supply-died/
No, it doesn't need more than that. The other 4pin is for more oc'ing power.
A 7950 can run off of a solid 450w but I wouldn't try it on anything like a no-name brand which is what your psu seems to be.
https://linustechtips.com/topic/248628-power-supply-died/#findComment-3414016
It's an old Thermaltake power supply from 2006 era plus or minus a year or two. It's actually 480watts. During it's day it was a high end PSU. The next one is 550w but I didn't bother taking it out of the system I am writing on. This one has a Q6600 running at 3.3ghz with a Thermalright 120mm heatsink. The original Thermalright 120. It has 8GB of ram DD2 1000mhz and an 8800GT. It's a classic in terms of computers. It has an Samsung F1 1TB hard drive.
https://linustechtips.com/topic/248628-power-supply-died/#findComment-3417417
I'd suggest getting a new psu for the 7950.
https://linustechtips.com/topic/248628-power-supply-died/#findComment-3417708
