Need help with choosing a Monitor for my Gaming PC
mike6715b
Go to solution Solved by C.G.F.Sabre,
I have saved up some cash and now i am ready to buy a new Gaming PC for myself. My current PC is Okay-ish but i want better! So far i made this PC : http://pcpartpicker.com/user/mike6715b/saved/TGQwrH
I'm still not sure if im going to buy the Monitor that i have selected but i thinking of going with that. For anyone that would like to help me with choosing a good monitor I want you to know this: I don't want it to go over $150 withc is for me the MAXIMUM for a monitor for this rig, I do want it do be a Wide-Screen, good refresh rate and all other good things that Linus said in this video:
Thanks in advance to ALL people that give me suggjestions.
Yeah pritty nice looking monitor and i dose have everything i ask for but i just want to see if we can find better ;)
like what esle. you cant get a fast refresh rate if you want good colors.
I would recommend a ssd if you can add it to your budget.
If you can reccomend one i just might! ;)
Its not that im looking for additional fitures its just that i think theres a better monitor out there and maybe just maybe a bit cheaper. :P
I think that was the only one that fit your budget that is a good gaming monitor.
The crucial mx100 is the best value ssd. It is faster and cheaper than the hyperx 3k. :) For a monitor, I would get the Acer h236hl bid. Great monitor for the price.
