Hey people of the Sploosh community
i'm looking at redoing my build and i'd like to  some how make
EK D5 Vario X-Top Plexi With Pump  and Alphacool Cape Corp Coolplex Pro 25 LT into one unit that is less than 390mm in length
Is there some top i can get for the pump to join them up or will i have to get another Res ??
Cheers, Aussie Pawz
https://linustechtips.com/topic/247305-pumpres-combo-questions/
Cheers, Aussie Pawz
Your link is dead. AFAIK, no. You can however, get a EK D5 X-RES 140 which is a pump/res combo of about 200mm in length.
If you want a longer res, you can buy those separately from EK too.
Bert & Ernie before squirting spermie.
https://linustechtips.com/topic/247305-pumpres-combo-questions/#findComment-3393380
Cheers, Aussie Pawz
Is this what your after, Here. ??
Only other way off the top of my head would be to put a male to male extension fitting between your res and pump. Thats if the res has a centered hole for it. Can't find a pic to show you what I mean. Found something close, take from hard forums.
MOBO: ASUS X79 Pro CPU: i7 3820 Ram: Corsair Vengence 32Gb 2133mhz (8x4) GPU: 2 x Sapphire R9 290 in X-fire PSU: Seasonic G series 750w Drives: 1 x 750 gig WD black, 3x WD Black 1TB, 1 x Segate Barrcuda 1 TB, 1 x Toshiba 2TB, Intel 520 240gig SSD Case: Enthoo Primo w/ Green and Blue LED lighting.
https://linustechtips.com/topic/247305-pumpres-combo-questions/#findComment-3393842
Hi shago yeah sorry about the dead link i guess they sold out and didn't want to carry that item any longer. i will have a look at what i can get
Hey Max thanks for the reply  i just checked the measurements of the res i have and it's only 50mm so it'd be to small for that res but yes that type of top for the pump but just to fit my  res
and i have a male to male fitting i was just looking at my other options as it wouldn't look as clean as having the pump res combo
https://linustechtips.com/topic/247305-pumpres-combo-questions/#findComment-3393891
I'm hearing ya there mate, but even that link was the only thing I could find at the time. Bout the only other thing would be to buy a pump res combo. Sorry I couldn't help you more. :(
https://linustechtips.com/topic/247305-pumpres-combo-questions/#findComment-3400704
