Nope it wont conflict. I have 4 and everything runs smoothly
I also have 2 copies of windows on 2 different HDD's and 1 copy of windows 10 on the other one.
https://linustechtips.com/topic/247224-need-help/#findComment-3391683
So, i want to put in an old hard drive into my new computer to get music from that hard drive... the only thing is that will the old os on that hard drive conflict with the new os on the new computer???
just make sure your regular drive is set above your old one that your putting in, in the boot order.
https://linustechtips.com/topic/247224-need-help/#findComment-3391684
so it was computer already put together so the original hdd should be first right? then just connect the 2nd hard drive and its all good?
Runescape player  II  Civ 6 and LoL noob  II
https://linustechtips.com/topic/247224-need-help/#findComment-3391714
The boot order *might* need to be adjusted. if you boot into the old OS, just change the order in your BIOS
~Remember to quote posts to continue support on your thread~
-Don't be this kind of person-
CPU:  AMD Ryzen 7 5800x | RAM: 2x16GB Crucial Ripjaws Z | Cooling: XSPC/EK/Bitspower loop | MOBO: Gigabyte x570 Aorus Master | PSU: Seasonic Prime 750 Titanium
SSD: 250GB Samsung 980 PRO (OS) | 1TB Crucial MX500| 2TB Crucial P2 | Case: Phanteks Evolv X | GPU: EVGA GTX 1080 Ti FTW3 (with EK Block) | HDD: 1x Seagate Barracuda 2TB
https://linustechtips.com/topic/247224-need-help/#findComment-3391741
