This past summer I built my first desktop, so far I've been extremely happy with it, just wondering what you guys think I could possibly do to spruce it up, I'm thinking CPU : 3?
CPU: AMD FX-4100, OC'ed to 4.2Ghz at 1.3v (standard clock is 3.6Ghz)
Motherboard: Asus M5A97 EVO
Memory: 8BG @ 2133mhz
Video Card: NVIDIA GeForce GTX 480.
Storage: 120gig Agility 3 SSD for OS and Gaming, w/ a 1TB Seagate 7200rpm drive for random stuffs.
Power Supply: Rosewill 650W bronze certified.
Wrap it all up in a Corsair C70 with a H60 slapped onto the cpu and that's my baby. Been running like a champ for a year or so now.
I was thinking perhaps an upgrade to one of the new AM3+ socket CPU's, like the 8350. Maybe grab another SSD and run it in a raid format? Just ideas. Not looking to upgrade the 480 yet, don't really see anything that will REALLY improve upon it while remaining worthwhile cost-wise. Thanks guys!
https://linustechtips.com/topic/2472-recent-build-cpu-question/
I think your rig is perfectly fine as long as you're happy. If you really want to spice it up a bit, getting a higher end AMD processor and a more recent graphics card would probably help it a lot.
I'm guessing your talking about raid 0? Yeah, SSD's don't generally need that. You won't notice a real world difference and reliability will decrease.
https://linustechtips.com/topic/2472-recent-build-cpu-question/#findComment-32885
+1 on the RAID setup.... RAID0 just not required.... If you need to upgrade, go for the CPU....
Forum Links - Community Standards, Privacy Policy, FAQ, Features Suggestions, Bug and Issues.
Folding/Boinc Info - Check out the Folding and Boinc Section, read the Folding Install thread and the Folding FAQ. Info on Boinc is here. Don't forget to join team 223518. Check out other users Folding Rigs for ideas. Don't forget to follow the @LTTCompute for updates and other random posts about the various teams.
Follow me on Twitter for updates @Whaler_99
https://linustechtips.com/topic/2472-recent-build-cpu-question/#findComment-32934
Another +1 on RAIDing SSDs. It only helps in benchmarks, it pretty much hates TRIM (unless your on Z77 w/ 11.6 or 11.7 RST or used modified drivers). Don't RAID SSDs...
https://linustechtips.com/topic/2472-recent-build-cpu-question/#findComment-33359
Upgrade the CPU to the 8350. http://www.anandtech.com/show/6396/the-vishera-review-amd-fx8350-fx8320-fx6300-and-fx4300-tested/5
The 4100 performs a tiny bit worse than the 8150, so there will be a noticeable difference on CPU dependent games.
https://linustechtips.com/topic/2472-recent-build-cpu-question/#findComment-33360
