PC mic on XB1 help
Go to solution Solved by Nasirdude3211,
http://www.amazon.co.uk/gp/product/B00E4DHO44/ref=s9_simh_gw_p23_d0_i1?pf_rd_m=A3P5ROKL5A1OLE&pf_rd_s=center-4&pf_rd_r=1ENX3ZF0D0AENY751HQC&pf_rd_t=101&pf_rd_p=455333147&pf_rd_i=468294
From what I have seen on youtube and heard from other people, that cable allows you to use any headphone and microphone combination on the xbox one; with the headset adaptor of course. I will be picking one up myself soon, as I am not interested in buying a second headset just for the X1. The cable was designed to work on mobile phones I believe, and from what I understand the X1 headset adaptor uses the same type of 3.5mm connector found on smartphones and tablets.
Yah m8 i saw the same thing just its all out :/
I found another cord thou
Headset Buddy : PC Computer Headset to 3.5mm Smartphone Adapter
So i have a PC mic which is 3.5mm and has 2 bands on it. I want to hook it up to my xbox one chat adapter but idk what i need to do so.
I only want to chat with the mic i have my headphones hooked up to my DSS2.
https://linustechtips.com/topic/247104-pc-mic-on-xb1-help/
https://linustechtips.com/topic/247104-pc-mic-on-xb1-help/#findComment-3391436
https://linustechtips.com/topic/247104-pc-mic-on-xb1-help/#findComment-3391593
