Case recommendations/your favorite case?
Working on my new PC build. So far I'm most attracted to Corsair's lineup, like the 760T, or maybe one from their Obsidian series. Recommendations on the best cases?
Things I look for in a case:
-See through window
-Made out of metal
-Excellent cooling
Thanks for any suggestions.
Current PC build: [CPU: Intel i7 8700k] [GPU: GTX 1070 Asus ROG Strix] [Ram: Corsair LPX 32GB 3000MHz] [Mobo: Asus Prime Z370-A] [SSD: Samsung 970 EVO 500GB primary + Samsung 860 Evo 1TB secondary] [PSU: EVGA SuperNova G2 750w 80plus] [Monitors: Dual Dell Ultrasharp U2718Qs, 4k IPS] [Case: Fractal Design R5]
https://linustechtips.com/topic/246797-case-recommendationsyour-favorite-case/
-See through window
-Made out of metal
-Excellent cooling
This is probably well below your budget, but the Corsair 230T and NZXT S340 are what I considered. The 230T wins though with the bright orange.
Remember to be a good citizen and choose a 'best answer' when your problem has been resolved!
(that way people know when a problem's been resolved)
@Spev
Phanteks enthoo pro / luxe / primo, NZXT H440, Corsair Graphite 760T , 780T, Anything case labs is very sexy. and finally Lain Li PC-D600. All good cases in my opinion.
MOBO: ASUS X79 Pro CPU: i7 3820 Ram: Corsair Vengence 32Gb 2133mhz (8x4) GPU: 2 x Sapphire R9 290 in X-fire PSU: Seasonic G series 750w Drives: 1 x 750 gig WD black, 3x WD Black 1TB, 1 x Segate Barrcuda 1 TB, 1 x Toshiba 2TB, Intel 520 240gig SSD Case: Enthoo Primo w/ Green and Blue LED lighting.
the best cases for air cooling, outright, are the silverstone Raven 5 and Fortress 5. I have the raven, and it's small, but still a mid tower, has a solid metal construction to it, although there are some plastic extrusions on it, but it has a window that I find is well placed.
If you want a larger, or more conventional case, then the phanteks enthoo pro/luxe should suit your needs well.
PCs
Branwen (2015 build) - CPU: i7 4790K GPU:EVGA GTX 1070 SC PSU: XFX XTR 650W RAM: 16GB Kingston HyperX fury Motherboard: MSI Z87 MPower MAX AC SSD: Crucial MX100 256GB + Crucial MX300 1TB  Case: Silverstone RV05 Cooler: Corsair H80i V2 Displays: AOC AGON AG241QG & BenQ BL2420PT Build log: link
Netrunner (2020 build) - CPU: AMD R7 3700X GPU: EVGA GTX 1070 (from 2015 build) PSU: Corsair SF600 platinum RAM: 32GB Crucial Ballistix RGB 3600Mhz cl16 Motherboard: Gigabyte Aorus X570i pro wifi SSD: Sabrent Rocket 4.0 1TB Case: Lian Li TU150W black Cooler: Be Quiet! Dark Rock Slim
Ft05!
The corsair cases are not really metal. Lots of plastic
NZXT H440 should cover your needs. I recommend the S340 whenever possible though because it's such a good case for cheap. Side panel window (it does get scratched VERY easily though), nice understated looks and nice to work inside with with a power supply cover to boot.
