Recently I decided to play WarThunder again but I seem to have an issue. When I join a server to play Tanks the graphics card would crash. The monitors will turn off. But the computer is on the sound is still playing but there is nothing on the screen. (One of my monitors displays a notice that says unsupported resolution).  My graphics card is a 7970 ghz OC to 1150 core and 1550 Mem (stable)
Here is my WarThunder settings
Anistropic 8x
AA 4x
Texture High
Shadow High
Clouds MAx
render resolution Slider to the far right (100%)
Terrain 100%
trees range 50%
particle density 80%
grass 50%
SSAO quality 50
shadows blur 0
Water reflections 50%
Render DX 11
Instancing Auto
Everything checked off except "Clouds in hanger" and "Old Videocard support"
Can someone check if they have the same issue. I have tried both 14.9 and 14.4 drivers they both give me the same result.
[CPU] i7 4790K OC [CPU Cooler] H100i [GPU] Evga GTX 980 SuperClocked [Ram] Corsair Vengeance 16 GB 1866 mhz [PSU] Cooler Master 1000w Silent Pro [storage] 256 GB Samsung 840 Pro, 1TB Seagate SSHD, 1 TB WD Blue 4 TB Seagate Nas. [Motherboard] Msi Z97 Gaming 5 [Case] Phantom 410 Red [sound] Onboard ALC 1150 [Headphones] Sennheiser HD 558 [Keyboard] Razer BlackWidow Chroma  [Mouse] Razer Deathadder Chroma [Mouse] Razer FireFly [Monitor] Asus MG278Q
https://linustechtips.com/topic/246567-graphics-card-issue/
I & a friend had that, would load into a black screen, but you can hear everything.
AFTER MANY ATTEMPTS - Had to re-download the game on my end from the beginning, and it all worked fine, and then copied that data to his machine and his was fine.
Maximums - Asus Z97-K /w i5 4690 Bclk @106.9Mhz * x39 = 4.17Ghz, 8GB of 2600Mhz DDR3,.. Gigabyte GTX970 G1-Gaming @ 1550Mhz
https://linustechtips.com/topic/246567-graphics-card-issue/#findComment-3384303
I have tried uninstalling WarThunder and reinstalling it. This worked for me. Until I installed 14.9 drivers. Then it gave me the issue again. When I revered back o 14.4 it didn't work. I am guessing you have to re-install warthunder after a graphics driver upgrade.
@SkilledRebuilds
https://linustechtips.com/topic/246567-graphics-card-issue/#findComment-3384405
@SkilledRebuilds
Try using DDU (Display Driver Uninstaller in safe mode) and remove ALL AMD GPU driver related stuff, and then re-try 14.4, maybe some traces are left behind screwing it up.
It may not work, but beats not trying it.
https://linustechtips.com/topic/246567-graphics-card-issue/#findComment-3384430
I have tried that before and it uninstalls some of the amd CPU driver as well (USB filter driver) And i was locked from my computer.
https://linustechtips.com/topic/246567-graphics-card-issue/#findComment-3384604
