Whenever I set my ram frequency to what it should be (1866) I start getting crashes and BSODs while playing demanding games. And WhoCrashed says this:
On Fri 11/7/2014 19:14:05 GMT your computer crashed
crash dump file: C:\Windows\Minidump\110714-5007-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x75BC0)
Bugcheck code: 0x1A (0x41287, 0x478, 0x0, 0x0)
Error: MEMORY_MANAGEMENT
file path: C:\Windows\system32\ntoskrnl.exe
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: NT Kernel & System
Bug check description: This indicates that a severe memory management error occurred.
This might be a case of memory corruption. More often memory corruption happens because of software errors in buggy drivers, not because of faulty RAM modules.
The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
crash dump file: C:\Windows\memory.dmp
This was probably caused by the following module: ntkrnlmp.exe (nt!KeBugCheckEx+0x0)
The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this.
However just a few moments ago I saw that my GPU isnt even reaching its default clock speed at 99% TDP in FurMark! (Changing ram frequency doesnt change this) Funny thing about this is that a few days ago GPU-Z showed that performance was limited by voltage stuff, now its power.
So is this the GPU? PSU? RAM? Mobo? Or a combination of some of them?
Here are my specs: http://speccy.piriform.com/results/NpNUXdenOkHuJvCngPIHnLl
Here is the minidump: http://s000.tinyupload.com/?file_id=95309830266999093136
https://linustechtips.com/topic/246469-need-help-with-potentially-bad-components/
Run MemCheck and tell us the results.
CPU: Intel i5 4570 | Cooler: Cooler Master TPC 812 | Motherboard: ASUS H87M-PRO | RAM: G.Skill 16GB (4x4GB) @ 1600MHZ | Storage: OCZ ARC 100 480GB, WD Caviar Black 2TB, Caviar Blue 1TB | GPU: Gigabyte GTX 970 | ODD: ASUS BC-12D2HT BR Reader | PSU: Cooler Master V650 | Display: LG IPS234 | Keyboard: Logitech G710+ | Mouse: Logitech G602 | Audio: Logitech Z506 & Audio Technica M50X | My machine: https://nz.pcpartpicker.com/b/JoJ
Is your CPU overclocked? If so, then you might like to set your BIOS to stock.
You can also see if there's a BIOS update for your mobo.
"Fighting for peace is like screwing for virginity"
- George Carlin (1937-2008)
Try XMP instead of manual memmory overclock
Then the PC seems to be stable. It seems to set itself on 1600 instead of 1866 which the RAM should be capable of handling. I would still want to know why this happens because if its because of a faulty component then maybe I could RMA it.
No overclocks and updated BIOS already.
What RAM do you have, it says its at 768Mhz x2 = basicly 1600 mhz RAM, doesnt say what model, maybe your ram is only 1600Mhz and cant do OC. Your MB can definatly handle OCing the RAM, but your RAM may be a bust.  If its a low profile RAM you should not OC it.
--- CPU:  AMD A10-7850k --- Motherboard:  ASUS X88MPlus --- RAM:  G-Skill 8GB Ripjaws X DDR3 2133 Dual --- GPU:  Integrated APU --- Case:  Aerocool Dead Silence Gaming Cube Case  ---
I have this: http://www.newegg.com/Product/Product.aspx?Item=N82E16820231538
