Triple Monitor
Luhan
No, since it has no iGPU.
What GPU...
Main Rig: CPU: AMD Ryzen 7 5800X | RAM: 32GB (2x16GB) KLEVV CRAS XR RGB DDR4-3600 | Motherboard: Gigabyte B550I AORUS PRO AX | Storage: 512GB SKHynix PC401, 1TB Samsung 970 EVO Plus, 2x Micron 1100 256GB SATA SSDs | GPU: EVGA RTX 3080 FTW3 Ultra 10GB | Cooling: ThermalTake Floe 280mm w/ be quiet! Pure Wings 3 | Case: Sliger SM580 (Black) | PSU: Lian Li SP 850W
Server: CPU: AMD Ryzen 3 3100 | RAM: 32GB (2x16GB) Crucial DDR4 Pro | Motherboard: ASUS PRIME B550-PLUS AC-HES | Storage: 128GB Samsung PM961, 4TB Seagate IronWolf | GPU: AMD FirePro WX 3100 | Cooling: EK-AIO Elite 360 D-RGB | Case: Corsair 5000D Airflow (White) | PSU: Seasonic Focus GM-850
Miscellaneous: Dell Optiplex 7060 Micro (i5-8500T/16GB/512GB), Lenovo ThinkCentre M715q Tiny (R5 2400GE/16GB/256GB), Dell Optiplex 7040 SFF (i5-6400/8GB/128GB)
Can a 8320 drive 3 monitors?
uhhhhhhhhh the 8320 has no igpu and a cpu doesnt affect the graphics heavily so wut
Please follow your topics guys, it's very important! CoC F.A.Q  Please use the corresponding PC part picker link for your country USA, UK, Canada, AustraliaSpain, Italy, New Zealand and Germany
also if you find anyone with this handle in games its most likely me so say hi
What GPU...
It has a r9 280 currently or will it be better with a nvidia gpu?
It has a r9 280
In that case, it's fine for everything. But don't expect to do triple monitor gaming.
If you use Display Port you can also daisy chain the monitors as R9 280 as DP 1.2. I do that it works fine for two but three in chain sometimes makes the driver crash so I just have one single and one chained with two. That way I only use the two mini dp ports on the card. I however have the R9 280X so not sure the i/o ports are same on R9 280 you have, but if so its an option.
We can build it, we have the technology!
So dual setup is fine?
I have had no issue with dual daisy chaining the DP 1.2 if your monitors support its with a DP out i/o. I only started getting random driver catalyst crashed with 3 daisy chained.
