CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($319.00 @ PC Force)
Motherboard: Gigabyte GA-Z97-HD3 ATX LGA1150 Motherboard  ($185.00 @ PC Force)
Storage: Samsung 840 EVO 120GB 2.5" Solid State Drive  ($115.00 @ PC Force)
Video Card: Gigabyte GeForce GTX 970 4GB WINDFORCE Video Card  ($629.00 @ PC Force)
Case: NZXT Source 210 Elite (Black) ATX Mid Tower Case  ($94.00 @ Paradigm PCs)
Power Supply: SeaSonic G 550W 80+ Gold Certified Semi-Modular ATX Power Supply  ($146.00 @ Paradigm PCs)
Operating System: Microsoft Windows 8.1 (OEM) (64-bit)  ($149.95 @ Computer Lounge)
Monitor: LG 22MP55HQ-P 60Hz 22.0" Monitor  ($199.95 @ Computer Lounge)
Keyboard: Cooler Master CM Storm QuickFire XT Wired Slim Keyboard  ($153.00 @ Paradigm PCs)
Total: $2264.90
Generated by PCPartPicker 2014-11-07 21:34 NZDT+1300
Last edit for this build I think since I got mostly all the things I want. All I need now is some advice for my PSU I was looking at the one listed here
Power Supply: SeaSonic G 550W 80+ Gold Certified Semi-Modular ATX Power Supply  ($146.00 @ Paradigm PCs) and this one Power Supply: Corsair CX 600W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($129.99 @ Mighty Ape) Is there a big difference between them and the fact that ones 80+ bronze and the other 80+ gold?
https://linustechtips.com/topic/246203-first-build-check/
Total: $2264.90
This is pretty good, I'd go with the corsair because i have more experience with them but its well balanced
https://linustechtips.com/topic/246203-first-build-check/#findComment-3379605
Efficiency is pretty unnoticeable between gold and bronze. The only difference is you'll have another ~47W to play with. I can't find much fault with the build other than the ram and motherboard not matching, that's it.
Don't know if I should match ram with mobo, since I have no idea what to swap it with as well. I'll be holding on to this build till christmas to start picking up things off this list since assume some things will drop in price a bit, because everything is overpriced here in New Zealand... So maybe I'll change the case to the NZXT S340 if it makes it to the NZ market in time
https://linustechtips.com/topic/246203-first-build-check/#findComment-3379660
http://nz.pcpartpicker.com/part/kingston-memory-khx16c9t3k28x
OR
http://nz.pcpartpicker.com/part/kingston-memory-khx16c9b1bk28
https://linustechtips.com/topic/246203-first-build-check/#findComment-3379667
If you can, go Seasonic. They are one of the best PSU manufacturers on the market even thou they are not cheap. And they make
Difference in efficiency is small but difference in quality of the components is noticeable between gold and bornze. Capacitors with higher temp rate and better build quality. So PSU should remain its efficiency for longer.
also check
http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story6&reid=323
ps: evga has pretty good PSUs too
ps2: regarding HDD if you have money, then go with 2 or 3 TB they have better price/tb
Lenovo E330 i5-3230M, 8GB RAM, 250GB Samsung msata SSD
mostly paired with LG 25UM55 ultrawide + 3TB WD Elements
Trackpoint rulezz!!
https://linustechtips.com/topic/246203-first-build-check/#findComment-3379698
if not you could get it shipped from ausralia
It feel unsure if I want to buy outside of NZ because if I get it shipped from another country it's gonna be a pain when I find it in pieces, I know that's unlikely to happen but I like being safe. As well warranty would be a pain.
https://linustechtips.com/topic/246203-first-build-check/#findComment-3382802
