Hi guys, does anyone out there know of any sort of yellow led that i could use for a potential up coming yellow and black pc build? Thanks!
I run my own indie game company called Color Dragon Studios where we are currently making a 2d platformer game called Small Earth.
https://linustechtips.com/topic/246077-yellow-led/
Ok thanks and can i cut this? Also how would i go about hooking up the light?
https://linustechtips.com/topic/246077-yellow-led/#findComment-3378012
idk, i was just suggesting you type yellow led in amazon. and gave the most impractical outcome that was still relevant
Oh ok well thank you for the help.
https://linustechtips.com/topic/246077-yellow-led/#findComment-3378054
i didnt really help, but if you get this
http://www.amazon.com/Yellow-Vehicle-Strip-Flexible-Waterproof/dp/B00ARYSAGU/ref=sr_1_4?ie=UTF8&qid=1415328843&sr=8-4&keywords=yellow+led+pc
and wire the red and black to molex connector it should work
https://linustechtips.com/topic/246077-yellow-led/#findComment-3378066
If you want to hookup the roll of LED's you need to solder on a positive and negative lead onto the LED and connect via molex on the 12V lead to power it, and it can be cut at specific cut points.
https://linustechtips.com/topic/246077-yellow-led/#findComment-3378222
You could get an RGB kit like...
NZXT Hue - $32
- 6 Ft. of led cable
- Different color Combos
- Head Unit
http://www.newegg.com/Product/Product.aspx?Item=N82E16811992011&cm_re=nzxt_hue-_-11-992-011-_-Product
Thats awesome, thanks for the recommendation!
https://linustechtips.com/topic/246077-yellow-led/#findComment-3384252
