I am going to be installing two nvidia geforce gtx 980's into my computer. Should the corsair ax860i (860W PSU) be enough watts or do i need more?
-Zinqs [-] i7 4790k @ 4.6 ghz [-] 2x EVGA Gtx 980 SC [-] Asus Maximus VII Formula [-] 16gb Dominator Platinum [-] Corsair Obsidian 750d [-]
https://pcpartpicker.com/user/Zinqs/saved/#savedbuild_1641021
https://linustechtips.com/topic/245792-how-much-watts-do-i-need/
860 will be more than enough; even 750w would be more than enough.
/If you didn't already buy the AX860i, then you should consider the EVGA G2 750w as it's cheaper and more than enough.
PSU Tier List | CoC
Gaming Build | FreeNAS Server
https://linustechtips.com/topic/245792-how-much-watts-do-i-need/#findComment-3373984
I'm going with two gpu's because i am going to be using three monitors and I still want to run smooth frame rates.
https://linustechtips.com/topic/245792-how-much-watts-do-i-need/#findComment-3374002
I have the ax860. It is frickin solid. I love it.
I'm not denying that; its an amazing psu....but I don't really see it being worthwhile over something like a G2, which is significantly cheaper. The Ax860i is like 1% more efficient, a bit shorter, and comes with a "puny" (lol) 7-year warranty.
PSU Tier List | CoC
https://linustechtips.com/topic/245792-how-much-watts-do-i-need/#findComment-3374022
Cheap is not always good... what certification level is it? Is it modular?
Gold and fully modular, I regret not buying an EVGA Power supply when I could instead of my CX430M
My current build - Ever Changing.
Number 1 On LTT LGA 1150 CPU Cinebench R15
http://hwbot.org/users/TheGamingBarrel
https://linustechtips.com/topic/245792-how-much-watts-do-i-need/#findComment-3374059
980 + 1080p Gsync monitor > 2x980
IMO
but if you got the money for 3 G-sync monitors and 2x 980 go for it
https://linustechtips.com/topic/245792-how-much-watts-do-i-need/#findComment-3374079
