2 SSD's on one sata power connector?
ledzz
2 SSD's on one sata power connector? is this ok, i have a sata power cable with about 4 connections on, is this ok? thanks
You can use all four of those connectors with four drives if you want.
PSU Tier List | CoC
Gaming Build | FreeNAS Server
It sure is.
SATA power no problem, SATA data would be a total clusterfuc mess.
 Two motoes to live by   "Sometimes there are no shortcuts"
                                           "This too shall pass"
I don't get it. How is the data transmitted then?
"Same rules since the first man picked up the first stick and beat the second man's ass with it."
The power connectors connect to the PSU supplying power for the drives. While the SATA data cables connect to the motherboard transferring data.
