I have always had a great success rate with corsair products but now I'm confused. Last night i did a build with a H60 and a NF-F12 as the fan and when I ititally booted up the system I had a weird whine from the cpu block I tapped it and it went away. Everything seemed okay until I opened up real temp to check my temps. Idle was 50-60 sometimes it drops to 40 but under regular use like browsing the Internet its between 50-60 and full load with small fft on prime95 yeilded 90+ degrees in less then 5 mins so I cut the test. I don't know what my problem is I feel like it has a faulty pump. Any input would be great
The bottom rad is for the GPU top rad is for the CPU in the picture.
https://linustechtips.com/topic/245239-h60-issue/
There is no picture but you could always RMA it. First make sure the block is actually seated correctly and if the problem remains then RMA.
DESKTOP - Motherboard - Gigabyte GA-Z77X-D3H Processor - Intel Core i5-2500K @ Stock 1.135v Cooling - Cooler Master Hyper TX3 RAM - Kingston Hyper-X Fury White 4x4GB DDR3-1866 Graphics Card - MSI GeForce GTX 780 Lightning PSU - Seasonic M12II EVO Edition 850w  HDD -  WD Caviar  Blue 500GB (Boot Drive)  /  WD Scorpio Black 750GB (Games Storage) / WD Green 2TB (Main Storage) Case - Cooler Master 335U Elite OS - Microsoft Windows 7 Ultimate
https://linustechtips.com/topic/245239-h60-issue/#findComment-3366374
