I'm currently living in university accommodation and I was wondering if there is a cheap way to stream games from my desktop PC in my room to the common room which is about 10 meters from my PC and through 2 walls.
For example if I got a very long ethernet cable could I stream through that cable into a second PC sat in the common room? Or could I connect them both to the same network via powerline ethernet since the student flats come with 2 ethernet ports, however the kitchen/common room doesn't.
PC Specs: CPU: i7-4770K @ 4.5Ghz (Cooled by Corsair H100i) GPU: 780ti (RIP) Mobo: Asus Z87-A Storage: 2x Samsung 850 pro (128GB) seagate SSHD (2TB) PSU: Corsair RM 750 Case: Corsair Vengeance C70 Peripherals Keyboard: CM storm cherry blues Mouse: Razer deathadder
https://linustechtips.com/topic/245096-ways-to-stream-games-help/
Does the steam streaming thing not work?
Listen if you care.
