27'' Monitor
GunMaster
Hi everyone!
I was just wondering if any of you has some suggestions for the ``best bang for the buck´´ 27’’ monitor. It needs to be 1080p and 60hz at least. Just the cheapest 27’’ monitor with these criteria. Anyone have any suggestions? Keep in mind that I live in Sweden so I might not have access to all brands and prices.
27in is a little too big for a 1080p monitor, I would recommend a 24in 1080p monitor instead.
CPU: Intel I7 4790k @ 4.6Ghz 1.255v | GPU: Gigabyte G1 Gaming GTX 980 Ti | Display: Acer XB270HU bprz | RAM: 16GB (4x4GB) Gskill Ripjaws X 1866MHz | CPU Cooler: H80i | Motherboard: MSI Z97 Gaming 5 | SSD: Mushkin 120GB + Sandisk 480GB | HDD: WD Blue 1TB | Case: Enthoo Pro |PSU: Seaconic M12II EVO 850w | OS: Windows 10 64-Bit | Mouse: Logitech RGB G502 | Keyboard: Thermaltake Poseidon Z (Brown Switches) |
How far will you be sitting from it?
SimRacer - Casual FSX Pilot!
Mobo: MSI B550 Tomahawk | CPU: Ryzen R5 3600 | GPU: Vega 64 Sapphire Nitro | RAM: 16GB Crucial Ballistix DDR4 3200Mhz | PSU: EVGA P2 1000W 80Plus Platinum | Storage: 256GB Samsung 840 Pro SSD - 1TB WD Black - 2TB Seagate HDD | Cooling: Dark Rock Pro 3, Noiseblocker eLoop Fans | Case: Phanteks Enthoo Luxe | Audio: Sennheiser HD598 - JBL LSR305s | Display: BenQ EX3501R, Asus VG278H
I'll be sitting pretty close guess. The reason I want such a large monitor is mostly for movies and also the general experience to be more immersive
Imo, 27" 1080p monitors only work if you are two feet or more away from them. I used one for years and it worked fine, but you just can't be too close to it without it just looking odd. If you want a 27" monitor I highly recommend looking into getting a 1440p monitor, I think it is about the perfect pixel density before being too hard to run and messing with windows text.
How much did it cost?
Budget?
My budget is somewhere between 400-500USD
For gaming mostly? G-sync possible (has Nvidia  GeForce GTX 650 Ti BOOST or above) ?
The 27" 1080 monitor? Less than $200. It is a S27C230B from samsung, it gets the job done, but you certainly get what you pay for. I'm sure someone here can recommend something better around that price.
