Hello forum!
I'm planing to build a new PC this summer with a MSI Z87-GD65 motherboard and I've opt for air cooling for it. I have in mind a CM hyper 212 evo for the CPU cooler. But is there any other better air coolers within the same price range of the hyper 212 evo. Or perhaps is there any other recommendations for better air coolers?
https://linustechtips.com/topic/24445-air-cooler-decisions/
Well a lot of people like this one http://www.newegg.com/Product/Product.aspx?Item=N82E16835608018
Or the xigmatek dark knight 2
i5 3570 | MSI GD-65 Gaming | OCZ Vertex 60gb ssd | WD Green 1TB HDD | NZXT Phantom | TP-Link Wifi card | H100 | 5850
“I snort instant coffee because it’s easier on my nose than cocaine"
https://linustechtips.com/topic/24445-air-cooler-decisions/#findComment-309613
The Hyper 212 Evo is one of the best coolers of its price points as far as I know. There may be a few others, but they shouldn't bet that much better.
You can't go wrong with the Evo.
https://linustechtips.com/topic/24445-air-cooler-decisions/#findComment-309649
Yeah I really like the temps it's getting under load. It's just just ram clearance I'm worried about. That heatsink is kinda beefy
https://linustechtips.com/topic/24445-air-cooler-decisions/#findComment-310376
Yeah I've done searching on the Web and people say it's really reliable for an inexpensive air cooler. But I'm worried it might now handle under heavy load when the cpu starts burning up
https://linustechtips.com/topic/24445-air-cooler-decisions/#findComment-310379
I've heard others get a 4.5ghz overclock on the 3570k with the Evo. You should be able to get a decent 4.0+ghz overclock quite easily.
https://linustechtips.com/topic/24445-air-cooler-decisions/#findComment-311610
