is the Hyper 212 evo a good upgrade to the i7 4790K
Yes, for lighter overclocking.
If you want to do some heavy overclocking/really push your chip hard, then you should be looking at something like an Noctua NHD15, Corsair H105, NZXT x61, etc...
PSU Tier List | CoC
Gaming Build | FreeNAS Server
https://linustechtips.com/topic/244406-cooling-question/#findComment-3353629
yeah pretty much anything aftermarket cooler is a good upgrade from stock, although if you plan on a lot of overclocking I'd suggest going watercooling
Please use http://pcpartpicker.com/ for everybodones sake!
and quote me if you want me to see a reply please :)
pewpewpewphysicslazers!!!
https://linustechtips.com/topic/244406-cooling-question/#findComment-3353634
is it quite
It's not loud at all. In fact, it's probably one of the best coolers on the market for under $35.
Gaming PC
  • SSUPD Meshlicious White Full Mesh
  • Corsair SF650 Platinum
  • ASrock B550 Phantom Gaming ITX/ax (Won a giveaway from OptimumTech)
  • Ryzen 5 5600X w/ Scythe Big Shuriken 3
  • 2x8gb G.Skill Flare X @3200 CL14
  • PowerColor Gigabyte RX 6750 XT
  • Storage:
    • Samsung 970 Evo NVME
    • Samsung 860 Evo 2.5"
    • MyDigitalSSD BP4 250gb (mSATA inside 2.5" enclosure)
  • W11Pro
  • AOC C24G1 + Dell S2415H
  • Cheap CyerPower keyboard (Wooting 60HE coming later this year)
  • Glorious Model O Matte White
  • LTT Northern Lights DeskPad 1000mm x 500mm
  • FX Audio Dac-X6 + Monoprice Modern Retro + Fifine Studio Condenser Mic
Media Server
  • Rosewill RSV-L4412U 12-bay hotswap
  • Unraid 6.9.2
  • Asrock B450 Steel Legend
  • Ryzen 5 3600
  • 2x8gb DDR4
  • LSI 9207-8I
  • 9x 2tb IronWolf • 2x 2tb WD Red • 1x 14tb WD Shucked White Label
  • MSI GTX 1050 Ti
https://linustechtips.com/topic/244406-cooling-question/#findComment-3353639
If you have the money, a Noctua NH cooler is much better (maybe not in terms of value really...) and quieter. If you have the money to buy a 4790k, I suggest you spend a bit more money on the Noctua cooler.
https://linustechtips.com/topic/244406-cooling-question/#findComment-3353640
yes, does not take much to beat the stock cooler. You wont be able to do any serious overclocking though.
Case: Phanteks Evolve X with ITX mount  cpu: Ryzen 3900X 4.35ghz all cores Motherboard: MSI X570 Unify gpu: EVGA 1070 SC  psu: Phanteks revolt x 1200W Memory: 64GB Kingston Hyper X oc'd to 3600mhz ssd: Sabrent Rocket 4.0 1TB ITX System CPU: 4670k  Motherboard: some cheap asus h87 Ram: 16gb corsair vengeance 1600mhz
https://linustechtips.com/topic/244406-cooling-question/#findComment-3353642
what is a good cooler for around a 100 dollars i care more about silence then anything else
https://linustechtips.com/topic/244406-cooling-question/#findComment-3353668
Noctua NH-D15
https://linustechtips.com/topic/244406-cooling-question/#findComment-3353692
NH-u12s, u14s, d15.
https://linustechtips.com/topic/244406-cooling-question/#findComment-3353705
what is a good cooler for under a 100 dollars i care more about silence then anything else
The EVO and Noctua coolers are good choices also Dark Rock 3\Pro 3 can be a good consideration, yes its expensive but you get what you pay for. A quiet premium product that'll last you quite sometime with some room to overclock if you really have to.
http://www.bequiet.com/en/cpucooler/482
We are one, we are many, we are, the Enthusiasts.
Cpu: AMD Fx-8350 Motherboard: MSI 970A G46 RAM: 18 GBs GPU: R9 290 w/ Kraken G10
https://linustechtips.com/topic/244406-cooling-question/#findComment-3353713
Would you be able to lend some advice? I'm using an Intel i7 980 and switching to fans instead of liquid cooling. I'm not overclocking though, but may in the future, not sure. Will the Evo be good? I don't mind spending some money...I want something that does not sacrifice on performance. I've ordered a Noctua Nh-D14, but I'm not 100% sure it will fit in my case. I did some measurements & I think it should. It arrives tomorrow, in the case that it is slightly too big I will need an alternative. How is the Evo? Or other HIGH PERFORMANCE Cpu fans? Like I said I don't overclock, but I play ultra games, stream, render, record, and do heavy tasks of my PC daily. My CPU gets a workout.
Current PC build: [CPU: Intel i7 8700k] [GPU: GTX 1070 Asus ROG Strix] [Ram: Corsair LPX 32GB 3000MHz] [Mobo: Asus Prime Z370-A] [SSD: Samsung 970 EVO 500GB primary + Samsung 860 Evo 1TB secondary] [PSU: EVGA SuperNova G2 750w 80plus] [Monitors: Dual Dell Ultrasharp U2718Qs, 4k IPS] [Case: Fractal Design R5]
https://linustechtips.com/topic/244406-cooling-question/#findComment-3354138
The 212 Evo is already more than enough if you weren't planning on oc'ing. The NH-D14 is much overkill.
https://linustechtips.com/topic/244406-cooling-question/#findComment-3357667
