BSOD when shutting down and Network trouble
Solved by STRMfrmXMN,
Hi everyone!
Recently I've had some trouble with my PC:
- When I shut it down it all goes well until it says "Shutting Down" (just before it should turn off), but it doesn't turn off and just says "Shutting Down" fro 5-10 minutes until I get a BSOD... (it had BCCode 9f).
- I have also noticed that my PC keeps disconnecting from my WiFi all the time. The WiFi still works for my phone and other PCs, but mine disconnects a lot randomly. When I try to reconnect it won't work until I "Troubleshoot the problem" - I think it says something about resetting the network adapter...
Does anyone know how to fix these 2 issues?
~ Oslosurfer
Turn your router off for the time where this event would normally happen. Pretty sure this will solve it.
